Question about Kenmore 62802 Electric Dryer
Kenmore elite dryer model 110 63032101 will not start no sound from timer or moter
Wont start not doing anything dead
rdial54
  • 14 Answers
SOURCE: model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Posted on Dec 23, 2007
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
SOURCE: my kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Posted on May 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
1996 Toyota Camry won't do anything when trying to start, nothing electrical works, won't shift from park. Battery has 13 volts.
you meant it wont crank , right? its silent/
no grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr sound.... like all cars do cranking?
you blew a main fuse. (nothing works, that means you key on
and the large numbers of idiot lamps are all dead, including the CEL lamp (EFI is dead if CEL is dead, no spark or fuel happens with ECU/PCM dead.) so is it?
if CEL is dead, oil, charge and freinds, all dead, the fuse is blown
for cluster or the main under hood.
this is easy, 13v on bat... make this easy.
Feb 03, 2014 | 1996 Toyota Camry
My bmw 320i 05 model wont start (no sound) and there is no dead battery sign on the dash board
If your battery is dead enough, even the dead battery indicator won't light. Take the battery to an autoparts store for a bench test/charge first before trying anything else.
Feb 19, 2013 | 2005 BMW 320i Automatic
Riding lawn mower wont start back up after running fine. it wont do anything after changing battery. just dead. please help
Down by the fuel tank there should be a main automotive fuse, if this has blown you will have nothing.
Jun 18, 2012 | Craftsman Garden
My battery is dead n car wont go in nuetral. my transmission saying it will not go in park...
leave it and put battery on charge you cannot do anything with a dead battery so do not force anything or you will break it and these cars are not cheap to repair
Mar 12, 2011 | 2002 BMW 7 Series
All the lights went on on the dash and now the car wont start, it turns over and the battery is ok but wont fire up, Any one got any ideas?
I GUESS YOUR COIL IS DEAD, BUT BEFORE YOU DO ANYTHING TRY STARTING YOUR CAR WITH SOMEONE ELSE'S BATTERY. SWAP THE SPARK WIRES IN THE FOLLOWING PATTERN
1=4
2=3
THAT SHOULD DO THE TRICK
Jun 14, 2010 | 1992 Toyota Celica
Wont start
check voltage in battery,check all leads and clean
Jan 01, 2010 | 2004 Ford Explorer
My battery went dead. plugged it in and wont do anything
mine is doing the same. i have a SanDisk 4GB mp3 video player & mines went dead too and it will show it charging for a few seconds then it will just stop & it will just show the connected sign. try holding the power button for 15 to 20 seconds. maybe that'll work
Sep 03, 2009 | Philips Audio Players & Recorders
Wont start
check the battery cables and make sure they are on tight...you may have a loose connection
Jan 29, 2009 | 1995 Ford Thunderbird
A55 1064 dead
Log in with safe more ( F8 I THINK ) then go with admin privileges!Go start run type msconfig then to startup AND DESALBE ALL COMPONENTS FROM STARTUP!
Let me know if u got help!
Mar 07, 2008 | Toshiba Satellite A55-S1063 Notebook
Kenmore 62802 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
