Question about Garmin StreetPilot C330 GPS Receiver
Shut down the unit boots up and finds the sats. then shuts down after about 2 min. it doesn't matter if on batteries or plugged in
  • 504 Answers
If you haven't done so, try charging the unit on the computer for a few hours. Sometimes this can help.
Posted on Feb 10, 2008
2005 dodge grand caravan sat for months put in new battery started and run I shut off try to start next day started and ran for 5 min. shut off on its own and will not start again .Battery started Ken
Check the battery voltage. If it's less than 12.2 volts, you've either got a charging problem or something is draining the battery. Read this post on how to find a battery drain.
Battery dead in the morning Ricks Free Auto Repair Advice
Dec 27, 2017 | Dodge Cars & Trucks
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
When I sit down to watch a movie my system sound shuts off after 3 min. I get up and wiggle the svideo cable and the sub powers back on and is ok for another 3 min or so. it repeats the same chacteristics...
The cord you are wiggling is not an S-video cable, it is a Mini DIN 8 connector. Both S-Video and Mini DIN 8 are the same type of connector, (DIN) except the S-video is a Mini DIN 4.
I'm not sure exactly what the problem is, perhaps you could enlighten me with some more info? Have you changed any audio settings in the menu lately?
First, try unplugging your sub from the power for 30 secs. Then plug back in.
Then unplug one speaker (doesn't matter which one but keep track of what you've unplugged) from the sub, wait the 3 mins and see if it shuts of again. If it shuts off again then plug your speaker back in and repeat this step with another speaker, until you've found the culprit, or run out of speakers.
Let me know what you find.
Nov 11, 2012 | JVC TH-M606 System
My company uses Panasonic Toughbook CF-18. We have ones that are over a year old, over 6 month old, and even just a few months old. In the past few weeks we started experiencing a problem where the units...
The battery interface has broken away from main board at the limit stop. Requires trained tech to repair. You mentioned these are new.. Cf 18 have been discontinued for years. Are these cf19's
Sep 08, 2011 | Panasonic Toughbook 18 CF-18NDHZX-VM...
Computer wont boot Evo d510
Choose within this options with regards to your monitor: 1. You could replace your monitor with a new one. 2. Or you could send someone or send it to a technician to repair your monitor.
Boot Up Problem: 1. Try checking the Power Supply Unit (PSU) if it give out 12Voltz. If not you could replace it with new PSU. 2. Check the motherboard if there are some blown out Capacitors. If there is, send it to a technician to replace it. If none, replace your Processor. That is the defective. That causes the boot up problem.
On boot up screen. Of course it will not show a boot up screen because there is a problem on your monitor. And so, there is also a problem on your motherboard (Processor or Capacitor).
Hope this might help. Thanks.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Truck sat for 6 weeks battery went dead. Charged
If checking battery cables and wiring to the starter and ground points doesn't help. Have the battery checked for a bad cell. Preferably before you charge it.
Feb 16, 2010 | 2004 Ford F150
Insignia p1020 plays for approx 1/2 hour when plugged into car adapter then shuts down. After restart, plays for about 15 min then shuts down,
There are a couple of possibilities: the battery is failing or your car adapter isn't working properly forcing the unit to play from the battery. First, try removing the battery and playing from the adapter. Also, try using the player from battery alone to verify that you're getting the expected battery life. If it turns out you need to replace one or both parts, you can purchase them here. I hope this helps.
Sep 23, 2009 | Insignia I-PD1020
Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
IPAQ hx 2110
You may need to purchase a new internal battery
Feb 04, 2009 | HP iPAQ H2200 Pocket PC
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
