How do I tune my changhong led combo tv/DVD without a remote? Has menu buttons etc but which button do I press to say OK
  • 556 Answers
SOURCE: Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Posted on Oct 02, 2007
SOURCE: Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Posted on Oct 05, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
  • 55 Answers
SOURCE: HOW TO TUNE GRUNDIG 14" TV
for tune your grundig you must use remote control
Posted on Dec 10, 2007
  • 476 Answers
SOURCE: setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Posted on Feb 24, 2008
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Jan 06, 2015 | Grundig 15 in. LCD TV/DVD Combo
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Changhong led combo need to auto tune with no remote
Is there a menu button on the set, if not Hold down the up and down volume button at the same time
Feb 13, 2014 | Televison & Video
How do i channl search my tv without a remote?
depends.....whats the type of tv and model? some tvs are fully remote controlled but if ya tv has a menu button press menu then press ok then select the options displayed by using the down arrowed button press ok go to search/tunig select auto tuning/search press ok it will select all channels automatically and store them press menu to exit
Jul 08, 2013 | Televison & Video
I am trying to reprogram the channels available on an Orion TV VCR/VHS combo without a remote and no menu button on this device's face for access
Hello
It is impossible to make an auto tune function to this TV without its remote control, as there is no Menu button on its front panel. OK.
Nov 24, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
How do I turn off the close caption on a Broksonic TV/DVD Combo without the remote
Try to press buttons simultaneosly for a few seconds to get to the menu, i.e. volume up and down together, channel down/up together etc etc
That very well may get you to MENU
Jun 12, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Locked dvd
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
Nov 20, 2007 | KLH KDT133UY 13 in. TV/DVD Combo
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
