Question about Plumbing
Culligan air gap faucet 01-0043-47 - Plumbing
2 Suggested Answers
h2oservices
  • 306 Answers
SOURCE: I just got a new sink and need to remove the
If it is the old style facet as shown with this post than you have to disassemble it from below the sink.
If it is the R2 D2 faucet (Plastic Chrome) this is how to do it. Pull the stem out, it just sits in there and is held by the o-rings. On top of the housing are two small screws, take them out, pull the cover off and you will see two screws on either side of the base plate. These are both toggle screws that hold the faucet onto the sink. Unscrew these and the whole assembly comes out.
RJ
Posted on May 23, 2011
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
I just got a new sink and need to remove the culligan air gap faucet from the old one. Is there a trick to remove the housing to get to the screws?
RJ
May 14, 2011 | Watts 116054 Standard Faucet with Air Gap...
Trying to connect Culligan drinking water filter to my faucet, BUT, the treads on the faucet are too high for adapters to reach. How can I connect? Also adapters aren't long enough to reach threads....
One thing to try is pick up a tap adapter, from an appliance store. The adapter is intended to connect a portable dishwasher or washing machine....these adapters have several small pieces that may be able to be used with the pieces from the Culligan adapter.
May 01, 2011 | Culligan Home
I have an AC 30 and it does not appear that the local culligan dealer installed the flush line correctly as per the diagram in the owners manual. It shows the flush line coming off of the faucet assembly...
The flush rate is dependent on the Membrane used (IE: 16gpd, 35gpd, 50gallons per day), the TDS of the water, the amount of water used daily from the RO and the size of the storage tank. When the RO is creating water (depending on TDS) you will waste about 3 gallons for every gallon of product water. If the system is under the sink and drains directly to the DWV line then yes the drain should be run through the AIR GAP faucet to prevent cross contamination of the RO system.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
Our Culligan water system under sink keeps backing up when we use it to get water - we only have this problem when we turn on the Culligan tap to get glass of water.
If you have an air gap faucet and the water is coming out there. The drain, for the RO, is plugged up or the drain line is pinched.
RJ
Jan 18, 2011 | Culligan Under Sink Water Filter
A replaced the Culligan 250A filters and now everytime you turn on the water from any faucet in the house you here 2 beeps.
I suggest installing an in-line check valve on the feed line to the Culligan filter and resetting the meter on the filter system. You may be getting water water feeding back out of the filter system when other faucets are run causing the meter alarm.
RJ
Aug 20, 2010 | Culligan Under Sink Water Filter
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Need to remove a culligan faucet
Culligan intentionally designed their faucet so that you have to have a culligan repair man come out. good luck
Jan 18, 2009 | Plumbing
Plumbing Logo
180 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
