Question about Philips SpeechMike Pro 6274 Handheld Digital Voice Recorder
Philips SpeechMike SDK - Philips SpeechMike Pro 6274 Handheld Digital Voice Recorder
Where do I download a driver for Philips Speechmike Classic 6264 that can be used with Windows 7?
Unfortunately I cannot find any references to driver installation for versions of Windows beyond Windows XP. The possibly means the hardware is not natively compatible with Windows 7. You can try installing the Windows XP driver using either compatability mode or if push comes to shove you can use the XPMode virtual machine to run the device in a true Windows XP environment with Windows 7 Virtual PC. I would contact Philips customer support for more information.
Feb 26, 2015 | Philips SpeechMike Classic 6264 Handheld...
Loss of words during reording
I suggest that you allow little more silent time before pressing the pause or stop. also when you start regording again let it go for a second or two and then start talking.
you may also tap the mic pefore starting speaking, performers always tap the mic pefore starting to make sure its working.
Jun 18, 2008 | Philips SpeechMike Pro Plus 5276 Handheld...
Can't get the record button to activate
Unless you can open up the unit to clean the contact for the record button it will have to be replaced.
Sep 04, 2010 | Philips SpeechMike Pro Plus 5276 Handheld...
With have Dell Optiplex 780 PC and have problems
It's known! The bad news is that the only way to make sure the device is recognized is to attach it through an external USB-hub (it requires 300 mA continuosly, and you can only trust the PC to allways deliver 100 mA - allthough USB 2.0 must be able to deliver 500 mA at occassions).
You should also disable any other sound devices, like built in Realtek, SoundMax etc.....
May 06, 2010 | Philips SpeechMike Pro 5274 Handheld Voice...
Can I use Speechmike Pro 6274 with Macspeech/Dictate
Sorry, the Philips line for Mac support is: "the market is not big enough". Appauling isn't it?
Mar 18, 2009 | Philips SpeechMike Pro 6274 Handheld...
Repair for Philips speechmike pro LFH52774/00
We had the same problem with our speechmikes,
If you are based in the UK,you can send them to a company called premicom.They fixed ours for a fixed price of £35 each plus vat.
They were very quick to repair and we had them back in a couple of days.
Dec 19, 2008 | Philips SpeechMike Pro Plus 5276 Handheld...
Won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Sep 01, 2008 | Philips SpeechMike Pro 5274 Handheld Voice...
Philips SpeechMike Executive V3.2 wont run in Vista
I had trouble initially with the same error message as deedee 222 8 and cannot give exact instructions. Try intalling old version, uninstall and then install upgrade 390 from Philips web site. I had to restart 3 times to get rid of an error messge on boot up but then it worked!
Jun 01, 2008 | Computers & Internet
Philips SpeechMike Pro 6274 Handheld Digital Voice Recorder Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
