Question about Acer Aspire 5551 Notebook
I am having intense troubles with startup repair
Alright guys I need your expertise with my computer, so as it stands I cannot get past my computers startup repair. I have an acer aspire 5551-2298 laptop with windows 7. Now startup repair isn't new to me I have been battling with it for a while but unfortunately using my quick methods (last known good configuration, system restore, safe mode) all aren't working. I have my acer recovery discs but I would rather not loose everything on my computer( if it comes down too it I don't mind). If any of you have any idea what to do please just help me out
    Habit-Forming:
    New Friend:
  • Acer Expert
  • 197 Answers
Try the ultimate solution http://www.majorgeeks.com/files/details/tweaking_com_windows_repair.html
be very carfull ..!! and run the program
Posted on May 03, 2017
    Sergeant:
  • 154 Answers
I can only tell you what my action would be on a system, you say its been in trouble for a while my thought would be a virus or hard drive fault. During boot up a system scans a file to organise how it will start this is read over and over again, over time it geats larger (with software, settings etc). If a hard drive start to fail this can lead to bad start ups, Windows tries its best to correct but errors creep in until it is unable to start through corruption of data.
A virus can also do this by starting up during boot and create a similar situation XP and Vista were very prone and I have seen several that "created double identities" from virus action until it became so confused after about 6 months or so froze.
Windows is built different but can still suffer to a less degree.
My initial action would be to remove the hard drive and run it up on an external usb set up on another laptop with Win 7 if you can get this to check it or use disk check tools on the web there are a few, plus run a antivirus program. While its running listen in to the drive gently hold it to your ear, if its grumbly or has like a clock tick sound it may well be faulty.
To copy a drive I use EaseUS free which I have found copes to a better degree with sick drives, you refit your drive, copy the program to a CD and boot up your system with it, a new drive is attached via the usb and follow instructions. If the drive is bad it may take hours if it works, on one I did which got red hot I left the cover off blowing cold air onto it.
If you do get it to boot up again run an antivirus with every feature on it has plus I use Malwarebytes free there are others but I have found this is good. After that run (MS) sfc (system file checker) and scan/check disk in full surface test mode, all this could keep it busy for several days. Do these before you use it and turn off any wi-fi links to stop any downloads.
I am sure there are other people who have their own ideas which are also valid but this is what I would do if it did not start.
You have to eliminate virus or drive errors before you can move on or things just get worse.
Hope this helps...........
Posted on May 02, 2017
  • 1019 Answers
SOURCE: Windows failed to start !...
Boot your computer with the recovery CD In the Drive.
You should get the option ** Boot From CD**
highlight click Yes, and overwrite the O/S.
This will re-install windows over your existing version, replacing any corrupt-deleted-missing Files.
mike @ compurepair.
Posted on Feb 24, 2008
jacobvizon
  • 31 Answers
SOURCE: once my laptop boots it freezes
try replacing the memory...
Posted on Aug 28, 2008
Geekman
  • 32281 Answers
SOURCE: acer aspire wont boot after improper shut down
It appears that you deleted some systems files.
You have been unsuccessful with System repair, then you need to reinstall Windows plus all your device drivers (eg. video, audio,LAN etc.) and your programs. If you don't have these drivers then go to a working computer and download them from the computer's WEB download/support site.
You will most likely lose your data in the process of reinstalling Windows, if you are desparate to recover your data, then remove the hard drive from the computer and connect it to a USB hard drive adapter and connect it to a working computer's USB port, this computer will see it as an external hard drive, you can then copy your data onto a CD or USB memory stick.
Posted on Dec 03, 2008
bradhscherer
  • 63 Answers
SOURCE: Windows cannot repair this computer automatically. Have already tried safe mode and last restore point.
run the repair from the install disk.
Posted on Jun 02, 2009
SOURCE: Unable to boot my acer laptop.
Hi Mike,
Thank you for contacting Fixya. This is Anil.
I understand that your computer is infected with Malware and now the computer is not booting to normal mode.
I can uderstand how frustrating this could be and I assure I will try be best to resolve this issue.
From the statement I understand that it may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now, restart the computer and keep on tapping F2 (some computers "DEL or Delete" key), you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer to Normal mode. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you
Regards,
Anil.B.R
Posted on Jul 18, 2010
I am having intense issues with startup repair
Hello. you can go to Programs and Features from the Control Panel and start deleting (uninstalling) all the tool bars and junk programs that are on your computer. That would make a difference but if I were you I would start backing up all the pictures, documents and anything else important to you. Depending on how much data you need to remove from your computer will determine If you want to use discs or an external hard drive. Then you can use your recovery discs and format your hard drive. Good Luck
Feb 13, 2014 | Acer Aspire 5551 Notebook
Google crome installation error 0x80070002
Alright guys i have the perfect solution for you
requirements:
-another computer/laptop that you got earlier with google chrome on it
-USB
-and just copy paste the files from the folder to your computer that you want chrome,if you dont have another computer/laptop sorry :( but if you do this will work i promise
Jun 16, 2012 | Google Chrome dev
I can't get my note book to start up in safe mode with networking it just keeps going to the tech guys screan and won't start in safe mode.
Hello
When your Advent laptop isn't booting properly, you probably have a problem with your startup disk. When the startup disk is acting up you may take it to a repair shop, or you may save a lot of money and fix it yourself. Windows 7 computers come with built-in software that will allow you to repair your startup disk in just a couple of minutes.
Start your computer and press down on the "F8" key. Click on the "Repair your computer" option in the "Advanced Boot Options" menu that appears on the screen.
Press the "Enter" key.Choose your keyboard layout on the next screen and click the "Next" button.
Click on the "Startup Repair" tool in the "System Recovery Options" screen.
Wait for the computer to repair the start-up disk
Apr 12, 2011 | Advent Netbook
Please my not less than one year old hp dv7 3165dx Pavilion is always shutting down minutes after startup...it never feels hott or wsrm to touch before this and the fan is working alright. No clogged up...
It sounds like your "automatic shutdown on error" setting is turned on. Here are the instructions to turn it off:
Restart the computer and press the f8 key to open the Advanced Boot Options menu.
Select the "Disable automatic restart on system" failure option.
Restart the computer to accept this change.
If there is an error, you will be able to see it after you disable this setting.
Mar 30, 2011 | HP Computers & Internet
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
run in safemode Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Sep 22, 2010 | HP Pavilion dv2000t Notebook
My computer is very slow and I need not much time left standing
The reasons for a computer being slow could be either that you have a full hard drive low memory or possibly and more likely you have malware on it. first thing to do is run and anti malware program like Malware Bytes
Download the free version and allow it to update and run a scan. once this has been done your PC should run a lot faster.
If not check your hard drive free space if it is below 15% you need to delete some of your old files and programs to free up some more
Jul 23, 2010 | Dell Computers & Internet
I have a HP Pavilion dv6700 lapt op and recently I installed a new game on it. When I exited the game to install updates onto my pC and restart, the color resolution was extremely distorted and all of my...
restart your computer, hold down f8 untill you see the windows trouble screen, on that screen choose: safe mode then when windows loads repair your resolution and, remove the game from your computer then restart the computer again
May 18, 2010 | HP Pavilion dv6000z Notebook
Scannning photo
I hope you get this message when you are trying to scan fom the All-In-One stand alone machine itself and windows operating system...?
If then follw these steps mentioned bellow:
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center/HP Director) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 28, 2008 | HP Officejet 4355 All-In-One InkJet...
Scanning
This message will come up when you are scanning from the Stand alone printer not from the computer.
If the software is sucessfully installed in your computer,
Then you should have a icon which says HP Director / HP Solution Center (If not Goto> Start> All Programs> HP and then you will see them
Open HP Director/Solution Center and try scanning from there, It should scan from there.
If yes then go to settings> Scann Settings> Scan to setup> There you see an option which says Front panel Destination list> Click that and there you see a options says Restore Defaults> Click that> then Apply and Ok> And close all the indows and try scanning from the All-In-One.
If it does not work then try the steps bellow:
Go To:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HELLO
you have a problem with blown (bad) capacitors on the pwer board google blow capacitor image and you will find them inside the flat panel soldering will be required.
Jul 03, 2008 | Dell E153FP 15" LCD Monitor
Acer Aspire 5551 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
