Question about Samsung 3.7 cu. ft. Stackable Front-Load Washer White Energy Star WF350ANW
Problem with samsung washer wf350 door latch - Samsung 3.7 cu. ft. Stackable Front-Load Washer White Energy Star WF350ANW
4 Suggested Answers
SOURCE: I have a two month old Samsung WF350 front load
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Posted on Aug 30, 2010
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
  • 330 Answers
SOURCE: The door on my Samsung Washer won't latch. It then
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Posted on Mar 14, 2011
DOOR WILL NOT LOCK TO WASH
The door lock has failed & needs replacing. The attached link will take you directly to the part you need. DC64 00519B DOOR LOCK I have also attached a step by step video on how to change a samsung door lock. Washer Door Latch Replacement Samsung Washer Repair part DC34 00024B
Jun 14, 2015 | Samsung 4.5CuFt White Front Load Washer -...
Does samsung washers have a reset button?
check the door latch is closing this is a safety feature so may need changing, a lot of people close the door with the power on, switch off at the plug before closing the door.
Mar 30, 2014 | Samsung WF337AA Front Load Washer
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
Nf code on a wf350 samsung
nf means that your washer has tried to fill but was unsuccessful. Remedy: make sure the water faucets are open all the way, the inlet screens are clear, and there are no kinks in the hose.
Jul 06, 2012 | Washing Machines
What does ds mean on Samsung high efficiency washing machine
A dS code means that the door was opened during the cycle. (At least this is true for the WF210ANW/XAA washer.) Close the door tightly and restart the wash cycle.
If the error persists, you probably have a problem with the door latch.
Samsung has the manual and trouble-shooting FAQs for many of their appliances here: http://www.samsung.com/us/support/ . Click on Washers & Dryers (in the rightmost column) then use the drop-down menus to select Washers and then the model.
I hope this helps. Please add a comment with the model of your washer for additional assistance.
Mar 20, 2012 | Samsung Washing Machines
The door on my Samsung Washer won't latch. It then displays DS error. Seems the roller in latch is down therefore not allowing door to close all the way.
Mar 13, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
I have a two month old Samsung WF350 front load washer. I have a trickle of water leaking from the bottom of the door during wash cycles.
Jun 26, 2010 | Samsung Washing Machines
Samsung WF7700N6W1 wont start because of 'door' error, door is closed
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Jun 19, 2010 | Samsung WF328AA Front Load Washer
Samsung 3.7 cu. ft. Stackable Front-Load Washer White Energy Star WF350ANW Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
