Question about Radio Communications
A health clinic ha s 3 1/2 quarts and 1 gallon of antiseptic wash in inventory. How many fluid ounces of antiseptic wash do you have on hand?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
240 ounces.
Posted on Nov 05, 2014
HOW MANY OUNCES IN A GALON/
128 fluid ounces in a us gallon
Apr 18, 2017 | In Office Equipment & Supplies
Tip
2007 Jeep Grand Cherokee Fluid capacities
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION FUEL TANK
All Models
76L (20 U.S. Gallons)*
ENGINE OIL
3.0L Diesel with Filter (10.0 Quarts)
3.7L with Filter (5.0 Quarts)
4.7L with Filter (6.0 Quarts)
5.7L with Filter (7.0 Quarts)
6.1L with Filter (7.0 Quarts)
COOLING SYSTEM
3.0L Diesel
13.2L (14.0 Quarts)
3.7L (9 Quarts)**
4.7L (14.5 Quarts)**
5.7L (14.5 Quarts)**
6.1L (14.8 Quarts)**
A/C REFRIGERANT SYSTEM
All Models
0.68 kg (1.5 Pounds)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 545RFE
2WD 5.2 L (11 Pints)
4WD 6.2 L (13 Pints)
Service Fill - NAG1
5.0L (10.6 Pints)
Overhaul Fill - 545RFE
13.33L (28.0 Pints)
Overhaul Fill - NAG1
7.7L (16.3 Pints)
TRANSFER CASE
NV140 and NV146
0.65L (1.4 Pints)
NV245
1.8L (3.8 Pints)
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
on Jan 04, 2011 | Jeep Grand Cherokee Cars & Trucks
What equals 48 ounces??
Hi Yesenia
There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
Cheers!
Nov 18, 2015 | Office Equipment & Supplies
How many ounces in 1 gallon of water
In the USA - 128 ounces = 1 gallon
Feb 08, 2015 | Home
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
Jun 28, 2014 | Health & Beauty
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
How do I mix the gas/oil on my farmtouch chainsaw
Most persons use a 50:1 mixture of gas to oil.
That means put one ounce of oil into a quart and a half of gas.
Or two ounces into 3 quarts of gasoline.
Or, a little over two ounces into a gallon of gasoline.
Aug 29, 2011 | Husqvarna Garden
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Dec 28, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
Fuel mixture for a mcculloch 610 chainsaw
40:1 is the manufactures recommendation as seen here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/62391767564ad36188256c2f001cbcd4?OpenDocument
I quart of premium fuel (32 ounces) to 3/4 ounces = 42.7:1
No chainsaw or any other 2 cycle device has EVER recommended 42.7 to 1.
I gallon of premium fuel (128 ounces) to 3.2 ounces is 40:1.
Any chainsaw outlet sells 2.6 ounce containers of 2-cycle oil that should be mixed with 1 gallon of premium fuel. That is 50:1 and may be safely used in all 2-cycle engines once adjusted to operate with this mix. Any mix over 1.5 months old should be consumed in a 4 cycle engine. HTH
Lou
Feb 04, 2010 | Garden
What is the gas mix parts oil to gas
Your manual says 40:1.
I gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
I gallon of premium fuel to 3 ounces of quality 2-cycle oil (.Oz/quart) is about 43:1.
Purchase the pre-measured 2.6 ounce 2-cycle containers sold at most chainsaw outlets.
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1.
Once adjusted with this mix your saw will start easier, plugs, pistons, and mufflers will take considerably longer to carbon foul. HTH
Lou
Jan 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Radio Communications Logo
1,483 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
