Question about Pioneer DEH-P3100 CD Player
Connect wires from stereo to car pioneer stereo
SOURCE: WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
Posted on May 26, 2008
  • 59 Answers
SOURCE: WIRING INSTRUCTIONS
Red=Positive 12v(switched)
Black=Negative ground
Yellow=Constant Power(Battery or fuse box W/ Constant power)
Grey=Right front+
Grey/Black=Right front-
Purple=Right rear+
Purple/Black=Right rear-
Green=Left rear+
Green/Black=Left rear-
White=Left front+
White/Black=Left front-
Blue=Amp turn on
Blue/White=Power antenna
Orange/White=Dimmer
Posted on May 30, 2008
SOURCE: car stero wiring diagram
ce3d034.jpg Here you go
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
dancandoit
  • 436 Answers
SOURCE: need wire color codes for a pioneer
try here, all pioneer wiring is the same.
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Posted on Nov 15, 2009
Why pioneer stereo works part of the time?
Loose connection on either speaker in pass door earthing out or broken wire from door to stereo connection
Aug 25, 2014 | Pioneer Car Audio & Video
How to connect pioneer fh-x700bt to a 2004 ford explorer
You need to buy a wiring harness compatible with your vehicle. The wiring harness will connect to your vehicle OEM plug and the other end you need to splice it with the wire that came along with your car stereo.
Apr 16, 2014 | Pioneer FH-X700BT
I need to know were the yellow wire gos dose it go to the red or blue for a pioneer car stereo?
The yellow wire on a car stereo head unit is usually the keep alive 12+, which allows the stereo's memory to be set and kept. It should be connected to a constant 12+ volt source.
Oct 07, 2013 | Pioneer Car Audio & Video
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Pioneer DEH-P3100UB car stereo keeps turning off and on again
broken wire, or dirty connection....oh check your ground wire for radio...
Jan 04, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Jan 23, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Dont know how to insall it !!!
Purchase the aftermarket wire harness at from a local installation shop. WIres will match color for color to this harness then mate to the factory connector. This could save hours attempting to figure out the factory wire harness.
Nov 11, 2008 | Pioneer DEH-2800MP CD Player
Pioneer DEH-P3100 CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
