Question about Mitsubishi VS-50707 50" Rear Projection Television
My picture is good but it is real dim. Would cleaning the bulbs help[ brighten the picture?
3 Suggested Answers
SOURCE: 2 new bulbs, still dim picture
It could be a dirty projection lense or the light engine is malfunctioning by a slipped lense in front of the color wheel or the light engine is dirty it self. They are not two hard to take out if the mounts have set marks on them then it is easy to put the engine the way it was.
Posted on Mar 18, 2008
  • 8909 Answers
SOURCE: picture very dim, new proj bulb. never cleaned
Cleaning the mirror would certainly elp but be carefull, it is very thin and brittle.
Posted on Jan 20, 2011
Display is very dim
Backlight bulb is burnt out. The display, on its own, will not generate enough light to read so there is a backlight bulb that brightens the display. Need to disassemble and see what type bulb is in there. Radio Shack should have a replacement if you bring your old one it.
GOOD LUCK>
May 25, 2016 | Audio Players & Recorders
Why do my boat trailer lights seem dim? Do I need a stronger flasher?
Too many bulbs on a circuit (flashers) will cause the system to flash rapidly. Dim lights more likely are a bad ground circuit. Many trailers use the ball as the ground connection. It is a poor one at best. Make sure you have a ground from the tow vehicle to the trailer (usually the white wire) Clamp a jumper cable from a good clean frame component on the vehicle and connect the other end to the trailer. If the lights brighten, you may have to clean/replace the ground.
May 24, 2015 | Boating
We have sound but no picture from our WD62530
you could have a ballast that has gone bad especiallyif it takes the bulb a long time to brighten up. look in the front of the set and see if the bulb indicator light tells to replace bulb or lamp. then you could try to reset the tv just in case this could unset an improper setting. the correct way to reset would be found in the user manual.
Mar 12, 2012 | Mitsubishi WD Televison & Video
Hello. I have a Mitsubishi WD-65732. We are experiencing TV shutdowns about once every two weeks. Also, unless it it my imagination, the picture seems to dim/brighten depending upon other things on...
I've suspect that your bulb has near to its end thats why you've encountered the subsequent shutdown and picture problem. This is the very common symptom of a faulty bulb. But since you've still watching your tv, this is not totally defective. I've advice you to look for a qualified technician to check the condition of the bulb before replacing with new one.
Hope it may help you.
Have a nice day.
Thanks for using Fixya.
Feb 11, 2011 | Mitsubishi Televison & Video
Whenever i open my head light at night, the dashboard light gets dimmed. I can't see my speedometer.
Theres a control below the light switch that will brighten the dash lights when in dim
Jan 21, 2011 | Ford Taurus Cars & Trucks
Hello, I got this Model in 2006 and my picture has got dimmer and dimmer. Is their just one bulb that needs to be replaced, and is it the bulb? Thank You!
there is more than one bulb, you need to call samsung to find out just how many. the bulb can be the primary fault , however all plasma tv's will dim more and more over time. It has more to do with the plasma panel though. replacing the bulbs may brighten the picture some however if it were only the bulbs you would have no picture at all. my personal opinion in this case would be to not replace the bulbs, i doubt that will solve your problem even if it does brighten the picture some i doubt it will produce the solution you are seeking. plasma tv's are great but they do have drawbacks, like the bulbs needing to be replaced and the fact that the panels get burn in . the problem you have is more to do with burn in than it does the bulbs. even thought there is no static image in one place ( what people think burn in is only ) the entire panel has " burn in " slightly which dulls the screen. i suggest buying a new tv, lcd or lcd/led to avoid this in the future. you can try to use the same thing they do to fix actual burn in of a static image, that may brighten the screen a little, however in some instances that is the culprit. to truely explain all this it would take a very long time , look up burn in on the internet and read about all the causes and solutions, you will then understand in a rather short period of time.
Jan 09, 2011 | Samsung HL-S6187W 61 in. HDTV
Overhead display too dim to use - can it be brightened?
I think it should brighten to the max with your dash light dimmer....You could put brighter bulbs in it.Hope this helps.
Aug 13, 2010 | 1993 Jeep Grand Cherokee
Dim picture on a sony kp 53s35 53in. projection tv
hello before you buy a bulb have tried the resetting the picture go into the menu on picture setting have half way down it should say reset click it .it should brighten up the screen
regards
sha
Mar 18, 2010 | Sony KP-53S35 53" Rear Projection...
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Mitsubishi VS-50707 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
