Question about Garden
Won't turn over
When you jump around solenoid starter kicks in. Won't turn over with key. Solenoid doesn't come in. Checked all safety switches, all ok. New ignition switch, new solenoid. Any ideas on what problem might be?
SOURCE: Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Posted on Mar 23, 2009
mrrichardlbo
  • 59 Answers
SOURCE: I just bought a used Craftsman LT100 19.5 IC
you forgot to take the carb off and check the float to see if it's bad if its a can you will get gas in it making it havey so it stops runing
Posted on Aug 15, 2009
cjrepairs
  • 60 Answers
SOURCE: ariens tractor won't start new battery new starter
check the grounding of the solenoid & ensure the circuit is complete
Posted on Sep 02, 2009
  • 66 Answers
SOURCE: Riding lawnmower will not start with key. I tried
Depend on the make and model of the mower....the safety switches usually are the seat, pto, shift lever, brake and clutch. If any of these are bad...the switch won't work. Can you cross the starter and have it start? With these safety switches....you can't just disconnect them to bypass. Most require a loop and running a wire from one side of the switch to the other will usually help you find the one causing the issue.
The solenoid comes in about 4 different models. Some ground to the frame and some don't. Not all key switches are the same either...we stock over 25 different switches and I could show you 7 that look identical but are different.
Personally I would start testing from the starter and work my way back...starter, solenoid, safety switches, starter switch. www.nnyparts.com
Posted on May 30, 2010
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
Ok so I bought a 94 Chrysler concorde... the guy told me you have to turn the key multiple times before it starts...the starter doesn't kick in until basically it wants to...lol he said the ignition...
You may be right. Sometimes a starter test doesn't reveal everything. But before you pull the starter, do this quick test. It should confirm if problem is the starter or the ignition switch. When the car won't crank over, pull the small wire off the starter solenoid (on the starter), and check if it has power when key is held in crank position. You need a helper to hold the key in crank. If the wire has power (use a testlight or meter to check for power), and the starter won't crank, pull the starter off for testing or replacement. But if there is no power on the wire when key is held in crank, then it confirms that power is not being transmitted from the switch to the starter. Not to say for sure it is the switch, could also be another part in the path from switch to solenoid (like the neutral safety switch). But more common for the ignition switch to go out first. Either replace the switch or continue testing your start circuit. Post back with results or for further help. Good luck.
Jun 14, 2012 | Cars & Trucks
Dynamark riding lawn mower won't start, new battery but will not turn over?
use jumper cable to test the starter if ok jump the small wire at the solenoid to power and see if it kicks it over if yes check the safety switches
May 13, 2012 | Garden
Daughters Car Won't Start
did u disconnect he ground on the battery,berfore changing th swicth, ther are two fuses / relay . one under dash and one under hood. if ther good ther is a back up fuse to comp. 7.5 read cover to be sure . take out for 10 min. replace and see if it helpes if not u may hav melted wires somewere. solenoid to to starter. good luk claymister
Dec 01, 2011 | 1990 Ford Thunderbird
2004 chevy tahoe won't turnover or start by being jumped
The ignition start circuit is the path from the ignition key in cranking mode to the solenoid on the starter. The path travels through a starter relay and a neutral safety switch before it reaches the starter.
This must be the circuit not working on your car.Make sure battery and starter connections are tight.Check for power at the starter solenoid terminal with a testlight when someone turns key to crank. If you have power there, they sold you a defective starter. If you have no power there then it could be the relay or the neutral safety switch.
Nov 28, 2011 | 2004 Chevrolet Tahoe
1966 mustang 289. won't start, jumped across solenoid, started. Replaced solenoid-starter wouldn't disengage, replaced starter, back to square 1, jumping across solenoid to start - whats my...
Ignition problem... No signal from ignition to solenoid...run a starter draw test to confirm starter is ok --- You can run your jump wires to a remote starter button or switch to get around it for now.
I hope this helps.
Sep 22, 2011 | Ford Mustang Cars & Trucks
John deere Z225 riding mower won't start .hour meter lights up .jumped across starter solenoid and it started three times and run.replaced with a new starter solenoid and nothing then tried jumping...
Sep 12, 2011 | Garden
Riding lawnmower will not start with key. I tried a new key switch and a new solenoid. I checked all safety switches and they checked out OK. I don't know if the wires for the solenoid are hooked up...
May 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 1989 f150 turns slowly when starting. I checked batt ok replaced ing switch key switch turns slowly but when I jump start it it starts right up cuold syarter be bad replaced solenoid on fender
it could be a bad earth on either solenoid or starter i had this with a ford capri about 8 years ago it would bump start and jump start but not start of the key once it had started once it would start again all day but after standing over nite no start i cleaned all earth connections and starter connections and it wos ok so i would try this failing this try new start solenoid or starter
Jan 31, 2010 | StarTech.com StarView SV211K 2-port KVM...
95 jeep cherokee country 6 cyl auto. wont crank all the time
Bad solenoid i would guess. Not making a connection there. Any basic wiring and ignition switch problems should be alleviated by jumping the starter with a screwdriver. I would check the solenoid and starter brushes
Dec 30, 2009 | 1994 Jeep Cherokee Country
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
