Question about Precision Scientific Thelco Model 4 Incubator Oven
Thelco (How to use)
How much water to add? Or do I need water ? Can I use with or without?
Cilinder in the middle
did you start engine on trailer without water turned on from a hose pipe and then turn water on once running ? try again on the trailer for 2 min without water with all sparks and cylinders running , if clean running then add water and if it falters you got a leak on the head or exhaust system ! P....
Jul 21, 2013 | R&D Pro Flow Power Plenum For Yamaha Gp...
Do you add water to the bottom pan before you state cooking with it?
Yes, you need to add a couple of cups of water first... more depending on what you are cooking...if the meat you are cooking will make its own juice then you need not add any more...also if you are cooking at a higher temp then like 350 then you may need more water as it will boil off...
heatman101
Apr 23, 2011 | Rival 18 Qt Roaster Oven with Buffet...
How do I add water to the pressa bella dry steam iron
Turn the big yellow top, if it's air tight use a plier and gently turn it. That will the trick.
WARNING!!! Becareful not to over fill the water reservoir by doing so the water boils making it leak. It is extremely dangerously as I steam burned my hand. Other than that u won't have a problem.
Jan 18, 2011 | Microwave Ovens
Do I need to put pump oil on this k2400 I mean the
the water should take care of lube and cooling. word of warning...absulutely,positively,do not run this machine without water hooked up and running thru the pump. just a minute without water,and the pump will be junk!!!
Dec 21, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Ran without water will not fill now
Try unplugging the machine for 30 minutes then plugging it back in. I am worried that the pump is bad due to the fact that it needs water to add resistance to work properly and without water the pump spins so free the it burns itself out. But first try unplugging the dishwasher first
May 22, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Battery won't hold charge
The battery should be taken out for a long drive or put on a charger for a few hours to determine if it is dead or not. a few minutes with the engine running will not let the battery recover sufficiently.
Check the water level in the battery, ensure the water covers the plates but is below the rings.
If you have done this, then the battery has probably sulfated and will need to be replaced.
Apr 14, 2009 | 2004 Dodge Intrepid
Moldy smell
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The problem is design. Not all of the water is getting out after each cycle and not all of the soap gets fully dissolved. After awhile, this mucky slime gets 1n the drain hoses, pump and filter - and they all smell musty - especially when the machine sits empty with the door closed between loads.
You need to clean the innards of the machine by doing a load without clothes on hottest setting (Whites) and depending whether the smell is bacterial (add 1 cup White Vinegar), fungal (add 1 Cup Bleach) or clogged filter (add 1cup Arm and Hammer with 1/4 cup SALT), this should do it
(Vinegar for Bacteria, Bleach for Fungus and Arm and Hammer with SALT to soften and loosen the slime)
Choose from above (not all 3 at once tho) and fill the machine with water and let run without clothes.
I would do the A&H with salt first, let cycle complete, then restart and add a cup of Vinegar, tel cycle finish then redo with 1 cup bleach
After treatment, leave the front door open after doing laundry from now on so it can thoroughly dry out and get air circulation. - Just open, not WIDE open ;-)
Cheers!
Mar 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The drain/spin cycle always adds water
It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
You could try shutting off the water supply at the taps before you start the drain/spin cycle.
Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
Precision Scientific Thelco Model 4 Incubator Oven Logo
37 people viewed this question
Top Precision Scientific Science & Laboratory Experts
William McMath
ray gallant
Are you a Precision Scientific Science and Laboratory Expert? Answer questions, earn points and help others
