Question about Precision Scientific Thelco Model 4 Incubator Oven
User info for Thelco model4 incubator(how to use)
I need to know how much water to add and the temp of the dial settings
Can not virw "This is Us" on NBC. Lets me select then goes back to main menu screen. Have roku in other room, no problem watxhing thatmone.
Below is the list of instructions on how to add channels from the Roku channel store to your Roku account activated through activation Roku code. In case if the user wants to add NBC com activate through Roku account can follow these simple instructions:
  • Select the Home button from the main screen.
  • Find the channel by selecting its category and try locating it.
  • The info option will let you know to know more about the channels.
  • The channel can be added instantly if it is of free of cost.
  • The channel has paid subscription then the user should be ready to pay for the channel subscription viewing it.
  • When the channels are installed it will be automatically added to the list of channels under the Home button.
  • If the user is fond of screensaver then he can try setting themes through the settings option.
Users can add the channels through the Website which many users don't prefer much. The users can automatically find channels in Roku device directly once the channels are added through web. They can instead sign into Roku account to add channel through channel store. For any further support for Roku troubleshooting or getting activation Roku codeusers can readily dial our toll-free lines for instant responses and expert solutions at +1-888-269-1011 and also visit our site for more info at https://www.go-roku.com/.
May 22, 2017 | Roku Televison & Video
I need instructions for a janoel 12 egg incubator please i have lost mine
Here are instructions from another website along with various links to download manuals and lead you to other forums talking about egg incubators:
Operating steps:
1. Put the mesh with the rail(big mesh)(fig.1) into the incubator.
2. Put the moveable egg tray (fig.2) on the mesh with rail, please do it within the rail.
3. Put the egg tray grille ( fig.3) into moveable egg tray according to size of egg for incubation.
4. Put the hatching egg into moveable egg tray(fig.5) for incubation, pay attention that after each egg is put into the grille, there should be 5mm clearance at least for convenient turning of hatching egg, inject 100ml water into the base after the hatching egg is put, check once for every two days so that the incubator is not short of water. Every water injection shall not be more than 100ml, take down the date of placing hatching egg so as to well control the hatching time. It's best to place the incubator on 60-100cm for convenient insertion of link rod.
5. When closing the cover(fig.7) , the link rod must insert the shifting slot of moveable egg tray, so that the egg tray can shift normally.( in other words, the cercley thingy coming out of the top with a rod in it has to be attached to the egg tray by putting the rod into the egg turner square hole to make sure that the incubator turns the eggs well)
6. Switch on the power supply after closing the cover, and set temperature according to push-button instruction and incubation technology. If the user has no time to care about the temperature, the temperature can be set at 38'c from the first day of hatching, and it can be set as 37.5 - 37.8C since the following day of hatching.
7. It moves to hatching tray 3 days earlier than incubation period for other poultry
8. It usually takes 3-4 days less than the number of incubation days for egg tray replacement, replace the egg tray once one or two hatching eggs are seen hatched, take all of the hatching eggs off from the incubator firstly, then take the moveable egg tray with mesh with rail out, check the water level, then put the hatching mesh( fig. 10) and egg tray in and put the hatching egg on the egg tray, shown as fig. 11.
9. After closing the cover and switching on the power supply, the hatching situation can be observed.
This was originally posted here: Janoel 12 incubator help
Best wishes,
Joe
Aug 25, 2016 | Hard Computers & Internet
Does anyone have an instruction manual for the JN8-48 Egg Incubator?
http://www.backyardpoultry.com/forum3/download_vault/JN848%20user%20guide01.pdf
Mar 16, 2014 | Bird Inc Digital Egg Incubator Thermometer...
User manuals
google user guide sanyo model sr-290 also the temp setting for 37 deg is 37 deg the numbers on the dial are only for reference you should get a thermometer for accuracy
Dec 01, 2013 | Sanyo SR-290 Compact Refrigerator
I need a user manual for a gallenkamp incubator inc200 model
I need user manual for Argis IO-1P TE Incubator for Chicken
Aug 07, 2011 | Ovens
Wish to set up O2 home broadband router model2 to act as a repeater for model4 O2 router to increase range
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then configure it in repeater mode enable wireless too.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Feb 02, 2011 | Computers & Internet
Does anybody know how to flash the firmware of an avaya 5610sw IP from the VPN to the regular in office
1) Edit your existing 46vpnupgrade.scr file as follows. Don't forget the line at the very bottom of this document!
2) Next set your phone's GROUP back to 0 by pressing the MUTE button (just press it don't hold it down) then enter GROUP on the keypad (47687) and press #.
3) Reboot your phone and the non VPN firmware should be re-installed on the phone.
# Release Date: August 26 , 2007
# 46XX Software Upgrade Script for VPN Capable H.323 IP Telephone
# This file upgrades the following telephones to the
# indicated releases:
# 4620, 4610, 4621, 5610 VPN Build 252
# 5620, 5621 VPN Build 252
IF $GROUP SEQ 0 GOTO NOVPN
IF $MODEL4 SEQ 4610 goto DEFVPN4610
IF $MODEL SEQ 4620D01B goto DEFVPN4620
IF $MODEL SEQ 4621D01A goto DEFVPN4620
IF $MODEL4 SEQ 5610 goto DEFVPN5610
IF $MODEL4 SEQ 5620 goto DEFVPN5620
IF $MODEL4 SEQ 5621 goto DEFVPN5620
goto END
# DEFVPN5610
SET APPNAME i10aVPN23252.bin
goto END
# DEFVPN5620
SET APPNAME i20aVPN23252.bin
goto END
# DEFVPN4610
SET APPNAME a10bVPN23252.bin
goto END
# DEFVPN4620
SET APPNAME a20bVPN23252.bin
goto END
# DEFVPN4625
SET APPNAME a25VPN25252.bin
goto END
# END
GET 46vpnsetting.txt
# NO46xx
# NOVPN
GET 46xxupgrade.scr
Oct 14, 2010 | Avaya 5610 IP Phone
Water will not stay hot long enough to shower...not familiar with any of these thermal expansion tanks and can't find any info on vacuum relief valve---40 gal water heater is 18 months old....any...
Turn the gas knob up. There's a dial on the front (probably red) and it will have settings on it. A B and C. Turn up to desired temp, but be careful of faucets if there are children in the house. Good luck
Dec 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
How hot does this heat tape get up too?
Sounds like you are trying to hatch chickens. The heat tape is designed to keep pipes from freezing, and will not be warm enough for an incubator. Try a heating pad or electric blanket, or if you are really serious, you could just BUY an incubator
Oct 02, 2009 | Easy Heat Water Pipe Heating Cable
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
Apr 01, 2009 | Ricoh Aficio 1013F Copier
Precision Scientific Thelco Model 4 Incubator Oven Logo
Top Precision Scientific Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Precision Scientific Science and Laboratory Expert? Answer questions, earn points and help others
