Question about Samsung DV520AGP Dryer
Samsung dv520agp dryer won't stop after clothes are dry
SOURCE: Samsung Electric Dryer
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
Posted on Sep 26, 2008
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
  • 686 Answers
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
ftw1952
  • 10319 Answers
SOURCE: 2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Posted on Apr 07, 2010
  • 8 Answers
SOURCE: My samsung dryer does not stop drying even when
You need to replace the main PCB board. They have upgraded the board.
Posted on May 06, 2010
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Tip
SENSOR DRY IN SAMSUNG DRYERS
As a tech, I'm constantly fielding questions about loads of clothes not drying properly in the larger Samsung dryers--and this tip can be used for a lot of dryers with the sensor-dry feature. Sensor drying uses a pair of metal strips located on the filter holder or on the back wall in the dryer. When wet clothes rub against the strips, this sends a signal to the main board which tells the dryer to keep going. Unless large loads are used, the consumer should use "timed dry". This is because smaller loads won't hit the sensor strips often enough and cause the computer to count down too rapidly. Also, consumers should try to make sure like items are placed with like items( shirts with shirts, pants with pants, towels with towels, etc) Thick clothing(jeans, heavy sweatshirts, etc.) usually will have damp spots like pockets due to the moisture not being able to contact the sensor strips--the technology is not 100%. Also, if there are problems with the timer starting to count down too rapidly all the time, and dryer sheets are used, the sensor strips may be coated with a waxy layer. Use some super fine emory cloth to polish the coating off of the sensor strips. You very well might find that the problem is solved and not have to initiate a service call!
on Sep 08, 2015 | Samsung Dryers
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Replace sensors on samsung dryer
Pleas seek the assistance from a registered gas appliance engineer.
Aug 02, 2014 | Samsung DV520AGP 7.5 Cu. Ft. Capacity...
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Samsung dv317 gas dryer takes forever to dry cloths. Cloths do not feel very warm when they are finally done. I changed the valves but still very little heat. It looks like the flame ignites but them it...
Easiest thing to check is the dryer vent. Maybe you've already done this, but make sure the 4" vent is not kinked or stopped up with lint. This causes the dryer to overheat. Hope this helps.
Jun 24, 2011 | Samsung DV306LGW Dryer
Samsung DV520AGP Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
