Question about Hitachi Televison & Video
VT M728E deck wont accept cassette, display suggests that a cassette is already in the machine but that is not the case
Modle Vt M728E
5 Suggested Answers
  • 59 Answers
SOURCE: Does not accept the video cassett
VCR....yowser...when you put the tape in does it look like its goign to load and then it either spits it out or just starts flashing? I smell smoke on this one. as in toast
Posted on Aug 27, 2007
JULIANFIX
  • 975 Answers
SOURCE: Drive belt for VT-428E VCR
YES !! belts are still available , you have to go to one of these ELECTRONICS PARTS shop , Im sure you will get the belts you need , good luck , AJ
Posted on May 11, 2009
BElectric
  • 1140 Answers
SOURCE: Hitachi VT MX705evps: after inserting
TRAC is short for TRACKING. This is rather complicated to explain and requires some understanding of how a VCR works. To put it in the simplest terms, tracking is an adjustment which corrects a misalignment between the image on the actual video tape and the playback head. The playback head basically "reads" the picture on the tape and sends it to your TV for viewing.
Many VCRs (including yours) have automatic tracking. When you insert a tape, the VCR attempts to adjust the playback head so that is in line with the image on the tape. The TRAC message will usually appear briefly when you insert any video tape to indicate that the VCR is perfoming this alignment adjustment.
In your case, the TRAC message is continuing to display because the VCR is unable to automatically correct this alignment and is therefore unable to read the tape. This is usually caused by one of two things;
1. A worn or stretched tape. Video tapes do not live for ever. After repeated recording the tape becomes worn, stretched and/or distorted. 8 hour and 6 tapes are particularly susceptible to this as the actual tape in the cassette is thinner and stretches/distorts more easily as a result. These tapes have a much shorter life expectancy than shorter 3 or 4 hour tapes.
2. The playback head is dirty and needs cleaning.
To solve this problem, you need to determine which is the cause. This is very simple to do. If the TRAC message persists when you use a brand new tape then you probably need to clean the heads. This can be done with a head cleaning cassette which you simply insert into the VCR and play for a short while:
http://www.maplin.co.uk/vhs-head-cleaning-system-9287?tabid=1&criteria=usb&c=so&u=strat15
This are widely available from many retailers, but be sure to follow the instructions carefully.
If the problem is confined to a single tape or a small number of tapes, then it's likely these tapes are worn out and have reached the end of their life. You may be able to get a limited amount of further use from them if you clean the heads as above (sometimes the problem can be a combination of a dirty head and a worn tape) but don't expect these tapes to last much longer. You would be ill-advised to use these tapes for any further recording.
In addition, if you habitually use 8 and 6 hour tapes, you should limit their use to recording things you only want to watch again a limited number of times. If you are recording things you want to keep and watch long-term, I would suggest using tapes no longer than 3 hours or 4 hour at the absolute maximum. For better quality and longer life, you should also record in short-play (SP) mode rather than long-play (LP) mode.
I hope this adequately explains the TRAC message for you. Please try a selection of other tapes - old/new and bought/self-recorded, then reply to me from within this page with the results if you need further assistance.
Regards,
BElectric
Posted on Feb 03, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Need User Manuals for TOSHIBA: - Video
Here's the link for Toshiba V753UK Owner's Manual.
Posted on Aug 27, 2011
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
My windscreen wiper wont turn off and my car is running unless i take the fuse out anyone no why its a vy 2003 modles
sound like the window wiper stalk has a short in it causeing the circuit to remain constantly on so might need to be replaced that would be the first thisng i would do then go further chcking wiring and fusines
Jul 16, 2014 | 1999 Holden VT
Radio wont accept correct pin no
there could be a couple of reason why it wont accept the radio pin.
Its possible that the radio pin you have is the orginal and maybe at same stage there was a fault with orginal radio and it was replaced under warranty the code wasn't updated .
Other is the bcm has been changed the codes hasn't been updated .
Jul 07, 2014 | 1998 Holden VT Commodore
What kind of amplifier to use?
Anything that accepts its common standard Line Level RCA inputs and outputs.
In case you don't have the manual. http://www.retrevo.com/support/Sony-TC-WE475-Tape-Decks-manual/id/268dj378/t/2/
Aug 25, 2011 | Sony TC-WE475 Single Cassette Deck
HOW DO YOU RECORD ON A V- TECH DECT 6.0 MODLE #CS6229
You can download the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/34/UserManual/1267/cs6229_manual_i3.pdf
The instructions to record an announcement are on page 12.
The instructions to record a memo are on page 32.
Aug 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a 52 inch RCA vt when you hit the power button it blinks 3 time but the tv wont come on its a modle D52W19B
replace the CP150, CP120 and CP114 capacitors. You can get the repair kit by the same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Jul 14, 2010 | RCA Televison & Video
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Apr 25, 2008 | Televison & Video
Aug 27, 2007 | Hitachi VTFX665A VCR
Televison & Video Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
