Question about Whirlpool 3.2 cu. ft. Plus Washer
Samsung front loader washer won't spin clothes dry model wf218anw/xaa
  • 1294 Answers
SOURCE: whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Posted on Apr 25, 2007
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
  • 85 Answers
SOURCE: whirlpool washer does not spin dry clothes
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 02, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
  • 662 Answers
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
No power to washer, can't open the washer door
http://www.appliancepartspros.com/parts-for-samsung-wf218anw-xaa-0000.html Look at the video section to see how to get under that machine and open the door and drain it.
Oct 04, 2015 | Samsung WF218AN Front Load Washer
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
I have a Samsung washer front loader it vibrates really bad when it is on spin cycle model #wf409anw/xaa
To test whether the problem is caused by a fault in the machine, or the way it's being used, run it through a complete empty cycle. No clothes, no detergent.
If it still vibrates under those conditions, call a repairman. If not, then the cause is an unbalanced load. This often happens when dis-similar weight articles are placed in the washer at the same time - such as bath towels along with tee shirts, etc.
Dec 12, 2014 | Samsung Washing Machines
I was Samsung washing machine model number WF218ANW/XAA It's making a flapping sound in the back during a spin cycle.
unplug and re-plug the Washer and check if the issue persists. otherwise click on this link for chat support http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=346139&modelname=WF218ANW&modelcode=WF218ANW%2FXAA&session_id=QBLGXKdDpFv5J32LF2rR81JCHqnryJpb6V1ldwQh6Wt1RQfLhRQy%211780044318%211589942691%211354844292695&from_osc=#
Dec 06, 2012 | Washing Machines
Samsung front loader model number WF218anw/xaa stopped after load finished and power is off. No lights. Door won't open. Circuit breaker okay. Socket okay. Is there a circit breaker assessable to...
Well unplug and hope that powers down your solenoid that is keeping it closed. Whats happening is that it thinks there is still water in there and it doesnt want you opening it. So if there is no water in there turn off circuit breaker off then back on or unplug for a moment to see if it resets itself. It should open on power down and if nothing else clear itself on reboot (yes there is a computer in there) . I would say you have a faulty sensor or the sensor is staying wet some how . try those and let me know
Jun 23, 2011 | Washing Machines
My Samsung WF218ANW/XAA front load washer will not drain & the display reads "nd". I have already drained the water through the front panel tube & have cleaned that filter, washer still...
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Jan 22, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
There is water left in the detergent tray after the wash is over
This seems to be normal for ALL front loaders
I just leave mine open along with the front door to dry out
Nov 06, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Apr 29, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Whirlpool 3.2 cu. ft. Plus Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
