Question about RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252
Accessory Handset not pairing - RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252
Panasonic user manual free download KX TGA740
The manual for the KX-TGA740 add-on cordless handset is available from the product page: http://shop.panasonic.com/support-only/KX-TGA740B.html?supportpage=true . The direct link to the manual is ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga740_en_om.pdf . You may find more useful information on using the handset in the manual for the base phone with which you'll pair the handset. The KX-TGA740 is compatible with the KX-TG6411, KX-TG6421, KX-TG6431, KX-TG6441 and
KX-TG7431 phone systems. To find the manual for any of these models, see http://shop.panasonic.com/support . Enter the appropriate model number in the search bar and press enter. Scroll down the page to the support section if the page doesn't come up in the correct section.
I hope this helps.
(the handset will work the same even if your handset has a different letter suffix.)
Jan 25, 2017 | Panasonic Lands Phones
I lost pairing on headset and iPhone. Tried to pair again but headphones won't pair with my iPhone now.
Pair your device with a Bluetooth accessory
  1. On your iOS device, tap Settings > Bluetooth. Stay on this screen until you complete the steps to pair your accessory.
  2. Place your accessory in discovery mode and wait for it to appear on your iOS device. ...
  3. Tap your accessory to pair.
Set up and use third party Bluetooth accessories
Mar 09, 2016 | Yurbuds Liberty Bluetooth Headphones Black
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
Apr 10, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Jun 14, 2008 | Cell Phones
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
RCA 25252 - Visys Cordless Expandable Phone/ans System - Telephones - Rca25252 Logo
21 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
