Question about American DJ Roto Balls Tri Led Lighting
American dj roto balls wont spin - American DJ Roto Balls Tri Led Lighting
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
I have two American DJ Emerald Scans. One of the lasers is not as bright as the other. What can I do to fix the problem?
Often mirror adjustments get knocked out of alignment. Open and check for this. Carefull of eyes from laser.
May 26, 2011 | American DJ Supply American DJ Emerald Sky...
I bought American DJ discolights with T20f control. I do have American Audio mixer and cd player CDI 300. 2 powered Mackie 450 speakers. How can I connect the stuff?
I can only give you some ground rules to follow: Connect ALL of the audio equipment to a single receptacle or power conditioner. This may mean running an extension cord back from where the speakers plug in to the mixer. Use BALANCED lines, either XLR or TRS to connect the speakers to the mixer. Power the lights separately. To give anymore suggestions would require a diagram of how your venue is laid out and the location of power, etc.
May 10, 2011 | American DJ T20f Chase Control Pack W/foot...
I am having trouble running an american dj quad gem in dmx mode. I have other lights that are working fine.
If by chance teh light is on the end of a long DMX cable run, read about putting a terminating resistor at the end of the chain. You say you are having "trouble"... that doesn't tell us anything that we could help you with.
Apr 23, 2011 | American DJ Supply American Dj Quad Gem...
Parts for american dj tri phase no sound attvation mic is fine
Usual problem is unit hasn't been put into sound activation mode. Make sure the display says:
"SOUn" and select the "on" in that mode.
Mar 17, 2011 | American DJ Tri Phase Led Lighting Dmx...
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
American DJ Roto Balls Tri Led Lighting Logo
32 people viewed this question
Top American DJ Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an American DJ Music Expert? Answer questions, earn points and help others
