Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
GE model gfss6kkxass front display will not let me adjust temp, only displays 88
What part needs to be replaced
4 Suggested Answers
SOURCE: Turn on fridge
Press the Ice Off button and the Freezer button together for thirty seconds. Set your temps at 36 for refrigerator and 0 for freezer.
if that doesn't work, press the freezer button and the energy saver button for thirty seconds and do the same thing.
Posted on May 30, 2009
heatman101
  • 43501 Answers
SOURCE: I have an ge french
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Posted on Sep 27, 2010
richroth
  • 9472 Answers
SOURCE: Our power went out for
All 8's in the display indicates the first stage of diagnostics. In other words your refrigerator is reverting back to test mode. If this occurs again after disconnecting the power from the refrigerator then reconnecting it, the main board will need to be replaced. The control board is located behind a panel on the rear of the refrigerator cabinet.
Posted on Jan 17, 2011
How to adjust temp. On control panel.ge model#pshf9pgzbcbb
Press the up or down key- once the display lights up you can adjust the temp... if the panel doesn't respond you need a new keypad
Dec 11, 2016 | Refrigerators
Ge gfss6kkxass front panel doesn't work
This repair is too complicated for the homeowner..
About the only this you can try is to unplug the power cord
wait 3-5 minutes and restore power. If no results I would
go to the main motherboard then to the display board..
These are R/R (Remove & Replace) parts and can be expensive
to repair..
Jul 27, 2014 | GE Refrigerators
Ge adora French door refrigerator has 88 on front panel and buttons do not work
Try removing all power for 1 minute, see if it resets.
88 on a display is a "test" display usually....all lights lit
also check if the controls are locked....top right button
Mar 12, 2014 | Refrigerators
Jandy panel reads 89 degrees, sta rite heater panel reads the right temp 78.
Standard 10K ohm sensor appears to be compromised. Replace it.
You have one for water temp, one for air temp, and one for the solar if you have one.
Feb 14, 2014 | Jandy Pool & Spa
This is my second attempt. I have a GE Profile
After you set it, the display goes back to showing the current temp. Just wait awhile and current temp displayed should change to the temp you set once it has had a chance to adjust. Give it a few hours.
Feb 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
New GE profile refrigerator bottom freezer model pfss6pkwass. Will not run, stuck in display mode. Lights are on but when setting temp on panel it goes back to off after a few seconds. After spending...
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Aug 13, 2008 | Refrigerators
GE profile fridge
Are numbers being displayed at all? If you want to confirm whether they are wrong or not, try putting a thermometer inside the fridge for about 10 minutes and check it against the temperature displayed. If it's wrong then it's probably the temperature sensor and would need to be replaced.
I suppose it's a long shot but could it be displaying 18 and feels more like 65? (Celcius vs. Farenheit)
Nov 08, 2007 | GE (JASHO96273)
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
144 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
