Question about Sony Ericsson Walkman W810i Cellular Phone
Radio frequency fades after few seconds
Hi,my w810i radio frequency fades byitself after few seconds when i tune a particular channel..immediately after tuning the reception comes very good but after few seconds the frequency fades and slowly vanishes completly,it happens with all the channells,plz help.
  • 425 Answers
Your headset wires are the antenna of your phone... be sure to let it loose freely to avoid the frequency fading... dont fold it...
Posted on Oct 29, 2007
Tuning to Indianapolis Weather Channel
Here is the link to the streaming radio. You can find the frequency too.
Weather Radio Streaming Audio Indianapolis Indiana
Jan 04, 2014 | Coby CX-18 AM/FM/Weather/TV Radio
Frequency for Motorola MU24CVS UHF (4 Channels) 2-Way Radio
This radio has several available frequencies built into the unit:
1 - 464.5000
2 - 464.5500
3 - 467.7625 *
4 - 467.8125 *
5 - 467.8500
6 - 467.8750
7 - 467.9000
8 - 467.9250
You would need to read out each channel to determine what each of the 4 channels is programmed to. Reading out is easy on this unit. With the radio turned off, select the channel with the channel knob, then hold in the PTT button while turning the radio on, immediately it will tell you the frequency number, (if you want to change the freq you can use the PTT button to walk your way up through the numbers to the number you'd like), then if you press the monitor button it will lock in your chosen frequency and it will tell you the private line code (if zero it is turned off), then press the monitor button again to lock everything in. Do this on each channel and you will know how your 4 channel radio is programmed.
Note: This radio is a wideband radio and only a few were produced with narrowband capability. After Jan. 2013 you are required to use narrowband only in the USA. If your MU24 radio has two RED dots above the word Spirit it is narrowband on only frequencies 3 and 4. If your radio has no red dots on the label your radio is wideband only.
Best regards.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
Radio not receiving on any channel
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Nov 27, 2012 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
Solam MP3 SL800E
Hello
How to use
1. Save your MP3 or WMA files into the car MP3 player directly from your computer.
2. Insert the 12 ~ 24V adaptor end of the car MP3 player into your vehicle's cigarette lighter
3. Choose you preferred frequency on your MP3 player, and then adjust your FM radio' s frequency same to the MP3's.
You should have received a user manual with your mp3 player, please read the manual, as with these chinese devices, we don't have the manuals to write down the instructions for you.
Jan 17, 2010 | Audio Players & Recorders
How do you operate the radio of nokia n71?
Hi!
For accessing radio pleae insert the headset and click for the radio option, now to set the frequency channels, go to the settings/options and click preset tuning.Now as per the clearance of the channel set the frequency and your radio will be set for use.
Thanks
With regards,
Lakshay
Sep 25, 2009 | Nokia N71 Cellular Phone
Radio lights up, but no TX/RX.
Hi and welcome to FixYa,
Based on your description, a possible drift in the local oscillator.  Check the 10.24Mhz crystal filter and its local oscillator for output and consistency.
Good luck and thank you for asking FixYa.
Aug 24, 2009 | Cobra Radio Communications
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Feb 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Tk-3100
Hi Tucaraca.
With the radio OFF, switch to CHANNEL 1, press the SQUELCH and the PTT at the same time. Turn ON the power switch while keeping the PTT and SQUELCH until the LED indicator turns RED.
Release the buttons and then press the PTT to CHANGE the FREQUENCY.
Press the PTT once each time until you get to the right frequency you desire. The 8 standard frequencies are as follows: 464.500, 464.5500, 467.7625, 467.8125, 467.8500, 467.8750,467.9000 and 467.9250 MHz. Once you get to the frequency you use, wait a few seconds and listen for the confirmation tone. Each frequency has a different confirmation tone so take note in case you need to program a second radio.
After you hear the confirmation tone, press the SQUELCH to confirm, and then press the SQUELCH again to lock the new frequency. Wait until the LED turns off, then switch off your radio.
Same procedure for CHANNEL 2.
WARNING: You must be legally licensed to use any frequency on any PLMRS such as the TK-3100 series. You must also apply for FREQUENCY COORDINATION and submit FCC form 601. FCC can impose steep fines and imprisonment if they catch anyone using an unlicensed radio on a controlled frequency. Visit FCC.GOV for more information.
Nov 27, 2007 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Sony Ericsson Walkman W810i Cellular Phone Logo
88 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
