Question about Argox X-1000 Thermal Label Printer
Printer wont print a test page - Argox X-1000 Thermal Label Printer
My HP PSC 1315 printer/scanner prints the test page every time I turn it on. A 2008 post from littlebluemuffi helped until now, but today it still printed the test pages.
This usually happens if the printer is not aligned properly. When you replace the cartridges, it prints a colorful sheet of paper. You need to place the paper face down on scanner glass and press OK button.
This completes alignment and the printer wont print test page again.
Regards,
Sean
Feb 25, 2013 | HP Office Equipment & Supplies
Our printer wont print out papers because it says its low on ink but we've bought ink and put it in, but it still wont print
Have you tried printing a test page from the printer itself.
There must be a menu on the printer through which you can print a test page or alignment page.
If it does print through that then it means that the printer is fine and there is some software glitch in the computer which needs to be fixed. But if in case it does not print anything at all through that as well then it means that there is something wrong with the hardware of the printer and needs to be taken care by Epson itself.
Feb 13, 2011 | Epson Stylus C88 InkJet Photo Printer
Printer wont print,prints test page. also I get
try to reinstall the printer driver first... and lets see what will happen... tnx
Jul 15, 2010 | HP PSC 1350v All-In-One InkJet Printer
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
Changed printer cartridge now wont scan printed sheet!Thanks,DV
Every time you put a new cartridge, the printer does a test page. That is because it is aligning your cartridge. Now what you need to do is take that test page and put it in your scanner as indicated on the test page. Then press "scan" on your printer. The printer should then do a scanner alignment and you should be able to scan. If you do not have that test page, print another one. Go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it.
Apr 04, 2010 | HP PSC 1410v All-in-One Printer
My hp printer 3535 wont printer.it says the files are ready.The printer wont print them.
Hi
Thanks for using FixYa. Please check that your printer has paper, has no paper jams and is currently set on the ‘use printer online’ settings by right clicking property and then setting it from there. Also please check that you have selected the correct default printer and drivers in the printer options. If there is any paper jams clear it. You can also check the few things like---
Please check that both ends of the cable which connects the printer to the computer are connected properly. To print a test page right click on printer properties and then click the 'Print Test Page' button and see if you get a test page printed properly. If you do, this indicates that the printer is properly connected to the computer and the computer has the drivers installed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | HP Office Equipment & Supplies
Printer will not print. I recently relocATED my computer, and now it doesn't print. I reinstalled the cd.. and I see my printer in the control panel, and it prints a test page.... but it wont print...
Could be a couple things, but if the test page prints it always means software/driver issue. If you're sure the driver is correct, here are some things I would check.
  1. Is acrobat reader installed? Quickbooks prints some things to and from PDF to the printer.
  2. Are you using a PCL driver on a PS printer or vice versa. Many applications, websites, etc require postscript.
  3. What default printer have you set, Windows will print to the default printer from applications but a specific printer when making a test page and you could be printing to MS imaging accidently.
Dec 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
Argox X-1000 Thermal Label Printer Logo
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
