Question about LG Televison & Video
Lg 60"pn 5000piture settings - LG Televison & Video
One side darker that other
the cause is either the back light get busted or connectors get worn out. but since it is a brand new you can avail the warranty just send it back to the supplier for check up.
Mar 24, 2013 | LG IPS226V-PN Flatron Widescreen LCD...
Lg monitor dual
The monitor L.G. is plug in my P.C. The driver is instaleted . But ...don t work ? Why ?
Jan 06, 2012 | LG E2250V-PN 21"LCD Monitor
Hi can a lg 22"e2260s-pn
According to LG's website the monitor has an HDMI input. Depending on the Freebox you have it could be hooked up through this port. Most DVD, Blueray, and tuner boxes will have an HDMI out on them. You would still need to output your sound. There is a headphone out on the monitor, so with a mini jack and a set of pc speakers you should be able to get sound. If not you could always wire from the audio out to an audio in on a stero/surround sound system.
Jul 19, 2011 | LG Computers & Internet
My LG E2250V-PN turns on and my Macbook goes to a blue screen, indicating that it is picking up a signal, but then nothing happens. My Mac screen never shows on my LG. Also, even if i try to press the menu...
Hi sophie,
I see you want to extend you monito to an LG external monitor.
Have you tried selecting the input PC or the input that is for the cable that you are using for the Video.
If you are using HDMI select the Input HDMI on your LG if you are using DVI then you should select the input DVI to be able to get the signal from the Laptop come out of your LG.
I hope this helps.
Have a nice day,
mvincentc
Jun 25, 2011 | LG E2250V-PN 21"LCD Monitor
Hello, i have an Lg rumor cell phone and i am trying to find out the 6 digit service code when you type in ##3282##, i have tried all zeros and other ones on the internet, and i was wondering some possible...
##33284 then do 77468 go to engineering then look for "active pn" or pn... this is your pin regardless of how many digits show it has use this as your msl or service code BAM SINCE I HELP U HOW DO I PIRATE ACTIVATION????
Oct 06, 2010 | LG RUMOR Cellular Phone
I had 3 red blinks in my KDF-60XBR950 Sony Wega.How do I jumper the door switch? What do I need to put to hold the switch?
The door switch is for safety. Is the door deformed (PN: X-4042-246-4), which is causing the error? Twisting the 2 wires together (after stripping) is a quick way to by pass the switch. If that fixes the problem, you should replace the switch (PN: 1-570-245-11). I hope this was helpful, best wishes.
Apr 24, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Philips HDTV
You will need to make sure the resolution pn the PS3 is set the tv picks up whatever signal is sent toit no adjustment has to be made through the set.
Jun 23, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
12 people viewed this question
Computer Repairing
Computer Repairing
