Question about Optoma HD65 DLP Projector
Projector fan is locked
My fan is lockec
A projector fan locks
The fan is faulty. Thats why the projectors shouts off. Almost all the projector fans built in with tachometer which counts the rpm of the fan and sent the information to the processor. If the rpm of the fan is low because of mechanical problems then the same problems can occur. Replacing the fan will solve the problem.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 02, 2016 | LG DLP SVGA 20001 200LUMENS W CARRY BAG ...
New ML500 projector shows:
I had the same problem. I opened the case and found that an insect had died and stuck to one of the fans, preventing it from rotating freely. I scraped off the remains of the bug and it works again.
Sep 01, 2012 | Optoma Office Equipment & Supplies
LG DLP projector fan lock problem
hi, i have fan locked problem on lg projector.
Apr 23, 2012 | Optoma HD65 DLP Projector
The card is lockec on my camera...how do you unlock the card?
1)Take the card out.
2) Examine closely the left side near the top. You will see a little sliding piece.
3) Move it to the "unlock" position (up).
Apr 06, 2011 | Casio EX-Z800SR Digital Camera
Hey my optoma hd65 bulb blew so i replaced it and when i powered it back up i received the fan lock error
the lamp probably blew because the fan stopped. if the lamp can't cool down, it blows. you'll have to find out which fan and replace it.
Nov 07, 2009 | Optoma HD65 DLP Projector
Projector will not turn on
are there any led lit or flashing? this will say if there is a problem and let you know what it might be. there may be a power supply issue, a cooling fan issue, or a lamp issue that will make the projector shut down by itself.
Aug 05, 2009 | Sony VPL-CX75 Multimedia Projector
IBM projector needs a fan replaced but can't find exact model
A locked rotor indication will stop the rotation of the fan completely, however if the fan is still rotating then it wont show "locked rotor signal". If the projector is still under warranty then locate their nearest service center and get it rectified..................sodeep
Jul 31, 2009 | Computers & Internet
Problem with my dell 1200mp projector
if you haven't already try cleaninig the filters
Aug 22, 2008 | Dell 1100MP Multimedia Projector
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
Optoma HD65 DLP Projector Logo
35 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
