Question about Samsung Np-qx411-w02ub 1tb Hard Drive 14" Laptop
My keyboard has issues
Some keys don't work. It has never been wet or broken or felt on the ground
I can not get in my log in as some number keys don,t work. When using Fn and the blue #keys the 8 and 9 don,t work as well. Is there a master log in with letters only to get in? My Service tag 28LK02J
Dell laptop some keys not working - Dell - Laptop General ...
www.tomsguide.com/forum/59513-35-dell-laptop-keys-working
May 13, 2012 - 7 posts - ‎4 authors
My dell Inspiron 1525 4,5,t,r,f,g,v And d keys are not working. can anyone ... If a group of keys fails it usually means that the keyboard matrix is broken. ... Dell laptop some numerical keys not working - Forum; Number keys on my ... wall also on my laptop so as to avoid any virus issues in future.....not sure if it ...Missing: d410
Why can my Dell Laptop connect to wifi but not get internet ...
en.community.dell.com/support-forums/network.../f/.../t/19406038
Dell
Sep 19, 2011 - 16 posts - ‎3 authors
I have a dell vostro 3400, and I can connect to any wifi network, and while ... to it, but they cannot get internet through it (even when my laptop gets it ... but I have no idea how to access the log it should produce... any ideas? .... Is there a reason that youdon't have DHCP enabled. ... Glad you got it working! keyboard some keys not working - General Hardware
Feb 28, 2013
DELL INSPIRON 15R 5520 - SOME KEYS NOT ...
Oct 20, 2012
White Screen - Video
Jan 4, 2001
More results from en.community.dell.com
Dec 29, 2015 | Dell Latitude D410 Notebook
My HP keyboard will not type /, but then the other way. (its after the 0 key. Key wit ? and + on)
probably your driver needs update or reinstall...
windows 7 OS : windows> computer> right click> manage > device manager> keyboards then update driver or manually download your keyboard model in HP sites :) goodluck
Nov 20, 2014 | New Hp Pavilion Notebook Dv7-2185Dx 2.0...
Four keys in Belkin wireless keyboard are not working
If only specific keys are not working, something is obstructing those keys\' pickups which are located immediately beneath the keys. This is almost always caused by food debris or liquid spillage as dust doesn\'t provide particles big enough to cause issues.
If those four keys feel "funny" when being pressed, it\'s almost certainly a physical obstruction. If they feel "sticky" it\'s always a liquid spill. If you don\'t recall spilling anything over the keyboard, use a can of compressed air (found at office supply stores).
Turn the keyboard long side up, with the keys leaning slightly downward. Place the air nozzle close to the intersections of the keyboard, starting at one side and work your way to the other side, using short bursts of air. Repeat for every row of keys. Pay special attention to the four that do not currently work.
You\'ll probably see lots of junk fall out of the keyboard. That\'s good, if so--I would then retest the keyboard (no need to reboot the computer). That should fix it--if not, you may have to resort to pulling off the keys that don\'t work. The next possibility would be broken key hinges, but that\'s beyond the scope of this reply.
For liquids, cleaning is hit or miss. If left long enough, liquids will eat away at the circuits, or provide a short circuit and kill the component. Since only four keys are affected, I\'m really leaning towards food debris, but if you did spill a liquid, you can disassemble the keyboard and clean up any residue under and around the keys. Probably best to use rubbing alcohol and a q-tip for that--but if you\'re not comfortable taking stuff like this apart, it might be time for a new keyboard, or find a handy friend. Good luck!
Apr 07, 2014 | Belkin Wireless Keyboard/Optical Mouse...
Keyboard problems
Not working at all? Did you spill liquid on it? Not working is a very broad statement, tell us exactly what is going on with the keyboard. If it's not working then you need another keyboard. If there are certain keys that work and some that don't then that's another issue.
Apr 26, 2012 | Dell Inspiron 1545 Notebook
I have a Microsoft Wireless Comfort Keyboard 4000. Some of the keys don't work at all. The ones that do work type the wrong letters. This is what I get when I type my name. darlene albin/uxgmtkt;xmwpk
Good day. I'll advise you to purchase a new keyboard because the the letter are already not correct which means the keyboard is already broken and there's no way to fix it. Im sorry but that's the only solution that can resolve your issue. Hope this information help you. Have a great day to you.
May 20, 2011 | Microsoft Computers & Internet
12347890 keys are not functioning including its respective alt keys.
Try cleaning out your keyboard, it may be a mechanical issue. Canned air can help you do this.
You can also try plugging the keyboard into a different USB port.
If that does not work, the keyboard may just be broken.
Mar 01, 2011 | Compaq Keyboard
Key board not working properly
The keybard probably has defective switches. They may have gotten wet or dirt in them. Not worth trying to fix. Buy new one...
They can be had off eBay for about $20 for brand new ones. Have a shop or competent person familiar with electronics work on it if you don''t feel capable.
The keyboard is USUALLY fairly easy to remove... USUALLY the second item to come off on a laptop when opening it.
Jan 29, 2010 | Sony VAIO VGP-WKB1 Keyboard
I AM UNABLE TO USE THE SPACE BAR AND NUMBER FUNCTION KEYS
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Open a screen you can type on. Hold down the space bar with a small tip (like the edge of an eraser), but don’t use anything so sharp it cuts through or that will leave ink spots. Hold it down and wiggle it on the bar keeping constant pressure for about a minute or until you see a response. See if you start getting a full or partial response from the key. If you do…the problem is dirt; if not, it is either dirt or broken…you may need to take it apart to clean it out, but this is common. There are plastic guards sold that prevent the innards from getting dirty and will save you a lot of grief.
Aug 24, 2009 | Dymo LetraTAG Thermal Label Printer
All keys in keyboard r no working
You can try but may be pure luck if it works: Cleaning the Keyboard with Vaccum Cleaner and blower. Also use a wet cloth and wet brush to clean it. Then dry it before use.
Power off PC and then Press all keys with both hands and then power on, have a try for Keyboard.
Otherwise it is the time to go for a new one, I would recommend to use a TVS gold keyboard having punching noise on it (similar to typewriter) than using a Multimedia keyboard (of soft keys press).
Since the former are repairable and the latter are not.
Thanks,
Fix it Out
Nov 13, 2008 | Computers & Internet
Samsung Np-qx411-w02ub 1tb Hard Drive 14" Laptop Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
