Question about Ricoh Aficio Office Equipment & Supplies
Printer ricoh aficio 7500 error code sc 534
Functionnal problem within the copier turn the operation switch off then on, if the error appears again, please call service sc534
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Posted on Dec 17, 2008
SOURCE: I am getting an error code SC 534 on my Ricoh
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Posted on Aug 05, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
  • 2072 Answers
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How to remouve error code sc 856 in ricoh aficio mp 7500
It is a wireless LAN error. If you do not use it turn it off in user tools.
Aug 11, 2014 | Ricoh Office Equipment & Supplies
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
