Question about Zalman ZM-M500WL USB Optical 3000DPI 4 Multi-button Wireless Mouse
Cursor tracking doesn't work in Zalman ZM-M500WL mouse?
I have a problem regrarding cursor tracking in new mouse zalman m500wl. Left/right click and scroll works fine, but there is no way to move cursor. What I already did to resolve the problem (and what just didn't worked) - put new bateries - restarting computer - changing mouse settings - change BIOS settings - looking for a drivers online (not found) - Editing Registry The mouse is new and never used. My PC: Windows 8, x64, Dell Inspiron Thanks for your help!
Zalman ZM-M100 driver
When you plug in this USB mouse it should automatically connect and install a driver if required.
Apr 16, 2013 | Computers & Internet
Cursor freezing
Hi
It could be trouble with Motherboard or the chip under the track pad.
Try to re-install the mouse driver. and try to check.
In case if you have any trouble then do contact us here in Fixya.
Thank you
Aug 11, 2012 | Advent Computers & Internet
Zm-RSSC v2 under
Dear i have send website address of your Windows 7 Ultimate 64x OS and the beta driver for Zalman Tech ZM-RSSC External Sound System.
please follow the instructions and keeps download it.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3124&Xlang=en_us&Xcntry=USA&source=XOG
Feb 16, 2010 | Zalman Tech ZM-RSSC External Sound System
Zalman RSSC driver problem
you may have to use the "safely remove hardware" icon in the system tray to turn off the USB module before unplugging it as it could be causing a power spike, also this could result in more permernant damage.
Dec 13, 2009 | Zalman Tech ZM-RSSC External Sound System
The fan is making a clicking noise, its on the left side and ive tried to blow into the fan, but it makes no difference. Its about 4 months old.
It probably sucked some object into the fan. the only way to clear it, is to open the laptop up and extract whatever is in the fan.
Oct 05, 2009 | Zalman Tech ZALMAN ACCESSORY ZM-NC1000S...
Good day
No. The ZM-WB5 is only compatible with Intel’s LGA775 and socket 478, as well as a few AMD processors. The Core i7's have LGA 1366 sockets.
Jul 15, 2009 | Zalman Tech Computers & Internet
ASUS cpu fan required
CPU fan is supplied with the processor it self you need to contact your processor company
it you are talking abt the Casing fan then just get an ordinary casing from from a hardware shop
Dec 13, 2007 | Zalman Tech Zalman North Bridge Chipset...
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Zalman ZM-M500WL USB Optical 3000DPI 4 Multi-button Wireless Mouse Logo
Top Zalman Computers & Internet Experts
David Payne
David Payne
Are you a Zalman Computer and Internet Expert? Answer questions, earn points and help others
