Question about Dishwashers
When starting dishwasher no water is coming in dishwasher
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Apr 11, 2014 | LG 24 in. LD-12BS6 Stainless Steel...
Water will not come in to my dishwasher The
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Feb 22, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
My GE nautilus dishwasher does not start and not getting water supply.
Dishwasher Trouble
heatman101
Dec 20, 2010 | GE Nautilus 24" Built-in Dishwasher
Whirlpool gold dishwasher is NOT getting any water on start cycle
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
No water is coming into the dishwasher. What should I do?
I will have to assume the dishwasher turns on when you press the start button.
Very hard to provide solution without knowing the make and model of the dishwashwer.
Possible causes of water not coming when dishwasher program has commenced are-
1. water tap is not turned on.
2. the water inlet solenoid in dishwasher is faulty
3. the float switch at base of dishwasher (depending on model) is triggered and thinks the dishwasher is already full of water.
Happy to provide a specific solution if i know the details. Please post a comment.
Jun 13, 2010 | Dishwashers
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Dishwashers Logo
11 people viewed this question
Top Dishwashers Experts
