Ps3 does not work on hdmi port for cptoh-0602 tv
SOURCE: hp 42 plasma tv cptoh 0602 I get sound but no picture
I had the same problem today, Hp wanted $629+tax to fix. With a little mechanical ablity anyone can fix this.
1. remove back covers
2. left-hand side is the video board
3. two white fuses
4. replace
this fixed mine and they only cost $1.50 each
Posted on Nov 26, 2008
dsacco86
  • 1077 Answers
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Posted on Jan 29, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Posted on Oct 26, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | HP Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Dec 31, 2009 | HP PL4260N 42 in. Plasma HDTV
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
