Question about Irons
Oliso 1050 I touch iron repair
My iron is stuck in the lift position and will not heat and red light stays on
bestdarngood
  • 3037 Answers
SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Posted on Mar 29, 2008
  • 1214 Answers
SOURCE: red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Posted on Jan 30, 2009
  • 65 Answers
element is shot,take it back or send it back for repair
Posted on May 31, 2009
SOURCE: Iron not heating up...
I had the same problem. There is a thermal cut-off switch mounted to the top-side of the base-plate. Unfortunately, you have to completely disassemble the iron to get to it. It is an easy replace, just make sure you take good notes on how it's all wired and put together. To disassemble the iron, I did this:
- Mount it in the cord base and move the switch to the "wireless" setting to remove the cord assembly from the iron.
- There are 2 small while nubs on the bottom of the blue plate in back. These are plugs. Pull them out to expose 2 screws.
- Remove these two screws plus the one in the center of the back blue plate.
- Pull the blue plate from the back of the iron and MARK all wires so you know where they go, then remove them.
- You will see 2 screws into the blue plastic base-plate at the back. Remove these.
- Open the door at the front of the iron where you pour the water in.
- Pry the spray nozzle at the bottom out (pry it forward). This will expose a third screw into the blue part of the base-pate. Remove this screw.
- Pull the white plastic and blue reservior away from the blue plastic base-plate. This will expose three screws into the metal bottom plate. Remove these three screws (on in front, 2 in back).
- Pull the blue plate away from the bottom metal plate. This will expose the thermal cut-off. There is a screw with a small metal clip holding it down. This is the part you will need to replace.
I bought my replacement part from a local electronics store. On mine, it was a 240 degree C cut-off. The part I used was from NTE. Part number is NTE8242. It cost me $1.40.
I suspect the reason this blew on my iron is because Oreck engineers didn't expect it to be plugged in all the time (my wife did not like the 'wireless' mode as it did not stay hot long enough so she uses it in 'corded' mode). If you use the iron on it's hottest setting in this mode, it appears that perhaps the plate gets hotter than 204C. That, or Oreck just got a lot of bad thermal cut-off parts and they are cutting off at a temperature lower than 240C.
Posted on Aug 03, 2009
SOURCE: Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Posted on Jul 09, 2010
My oliso tg1250 has stopped lifting,what can I do??
Call 1-800-899-5157 - or - email customerservice@oliso.com
They made this and they are the experts.
  • THeT
    Apr 06, 2017 | Oliso Irons
    I have a oliso iron that is one year old. Just not turning on.pluged into socket
    take it in to an appliance repair shop( possible cord problem) otherwise consider a new one as repairs past a cord are uneconomical to repair
    Dec 10, 2016 | Oliso Irons
    Oliso auto lift not retracting
    Its can be your switch inside it so you have to strip it and cut it out its a small its like a resistor you can brigde the wires its also fine or you can go and buy a new one and put it again but you will need to solder it back
    Sep 12, 2014 | Irons
    No heat
    take it to an appliance repair shop for a diagnosis of the problem
    it it was new 2 months ago take it back for a warranty replacement or refund
    Nov 11, 2017 | Oliso TG-1000 Iron
    Oliso iron will not give much steam, nor will it get hot even on the highest setting, only a few months old
    It has a THERMAL PROBLEM SETTING!
    If u said u just bought it a few months ago, it is still under warranty and u could bring that where u bought it and have them repair/replace it!
    Dec 02, 2010 | Oliso TG-1000 Iron
    Iron leaks , lift stuck in up position
    Here is a tip that will help you with that problem...
    My Steam Iron is Leaking Water
    http://www.fixya.com/support/r5301301-steam_iron_leaking_water
    heatman101
    Jun 12, 2010 | Oliso TG1100 Iron with Auto Shutoff
    My oliso iron is not heating up yet all the lights go on when I plug it in and turn it on.
    Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
    Electric Iron not Heating Up or not Working Right
    http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
    heatman101
    Nov 30, 2009 | Oliso TG-1000 Iron
    Light comes on, but iron will not heat up
    oliso iron turns on when plugged in green light flashes but iron will not heat up
    Feb 13, 2009 | Irons
    Irons Logo
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
