Question about Air Tools & Compressors
Evercraft spray gun - Air Tools & Compressors
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
Rolson spray gun 70809 not spraying
the paint may be to thick for the gun. or it could be clogged. try spaying plain water through it if it sprays you have your paint to thick
Jul 14, 2012 | Air Tools & Compressors
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
What are the controls of a gravity fee spray gun
most spray guns are basically the same gravity feed is no different, air pressure into gun and out nozzle,spray pattern fan to spot and last the amount of fluid comin out of cup to the nozzle.
Aug 28, 2009 | Ingersoll Rand 1.4MM HVLP GRAV FEED SPRAY...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
