Question about Garmin EDGE 705
Register garmin 705 - Garmin EDGE 705
My Garmin 705 is frozen with the garmin logo. Cant get pass that. Any ideas?
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults .reassemble
Mar 21, 2013 | Garmin Edge 705 Handheld GPS Receiver
Garmin 705 - device not found by Training Center
Garmin has moved everything to Garmin Connect. Depending on your device, Training Center may or may not be supported anymore. You can go to the link to read more on Garmin Connect. Also, Garmin now uses Garmin Express to sync and update devices. I'll attach the link. https://www.garmin.com/en-US/software/express
Aug 16, 2017 | Garmin EDGE 705
My garmin edge 705 will not turn on ?
Cant solve it. Buying Garmin --- get used to it not turning on. Problem since the launch of the EDGE models. Still a problem.
Feb 17, 2010 | Garmin Edge 705 Handheld GPS Receiver
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
We bought a new garmin 705 and the speed records but not the distance or other features
The Garmin Edge requires that you press the start/stop button to record any data.
1. Before you start riding, press the start/stop button to begin recording.
2. Once you have finished riding, press start/stop button to end recording.
3. Create an account on connect.garmin.com and plug your unit in using the supplied USB cable and download your ride to view details on your cycling session.
Aug 14, 2009 | Garmin Edge 705 Handheld GPS Receiver
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
The cadence sensor will not sink to my edge 705
Please perform pairing as described in you user's manual. Device must be paired before becoming available.
http://www8.garmin.com/products/manual.jsp?product=010-00555-20
Apr 05, 2009 | Garmin EDGE 705
Garmin EDGE 705 Logo
57 people viewed this question
Top Garmin Cycling Experts
SHARCNET-USA
SHARCNET-USA
perdue40
TO Lady
Are you a Garmin Cycling Expert? Answer questions, earn points and help others
