No output from DY-1420 Dynacharge battery charger
I need a repair manual fo a pitire 1420 EX Do you have one?
Check your batteries to see if the will accept a charge. These batteries only last a year or two under normal use, but far less if it is not being used or have a trickle charger on them.
Do a search for your scooter in your browser. Go to the eBay listing and you will generally find the brands home page, or manuals page.
Jul 04, 2014 | Drive Medical Spitfire EX 1420 Travel...
MY DELL INSPIRON 1420 WHEN I PLUG IN BUT NOT CHARGING HOW TO FIX IT.
Hello, you may find this to be the fault of the charger itself. Dell chargers have a micro thin communication wire that tells the battery to chage and when to stop charging. But this tiny communication wire within the charging cable is very fragile. If it breaks inside, then the laptop battery will not recieve the signal to make it charge. Replacing the laptop charger may be your solution. But it will need to be another Dell charger compatible with your laptop
Dec 23, 2012 | Dell Computers & Internet
My dell inspiron 1420 looked as if the battery were running out, as the little battery picture showed a little x, but when I go to charge the battery, nothing happens. Now my computer won't even turn on. ...
Try to use a USB charger for the battery. It is around 20$ and you can plug the battery in that charger.
It's is just a temporary solution. Also it could be great if you could test with the same type of battery but from another laptop.
If you need further assistance, or further questions just leave a comment. Thank you for using FixYa. Cheers
Jan 19, 2011 | Dell Inspiron 1420 Laptop
Battery is not charging when connected to charger
The problem might be in the battery or in the charger. If you have a multi-tester check the output voltage of the charger. The voltage output must go with the rated voltage in the battery. If there is output volyage in the charger then the problem is your battery. If there is no output voltage then the problem is your charger. Take time to check both the charger and the battery to make sure which to replace.
Dec 07, 2010 | LG Shine KE970 Cellular Phone
My GPS isn't charging and it keeps shutting down saying low battery, even though the charger is plugged in. I have tried it in 2 cars and it still does it. I don't know if it's the charger or the unit;...
I had this model years ago. Once the battery refuses to recharge, forget it. This model and its accessories was discontinued some time ago. You might be better to buy a new one. You can try to find a charger on ebay, but I would say it's time for an upgrade anyway.
Jan 08, 2018 | Magellan RoadMate 1420 GPS Receiver
My dell Inspiron 1420 will not power on. when the power button is pushed the power light comes on for about 3-5 seconds followed by the battery light for about 1 second and thats it. nothing else comes on...
a dell inspiron 1420 is a laptop you have put it under printers
im assuming your talking about a laptop
try charging your laptop or turning it on with the charger still attched to the laptop
if laptop does not turn on with the charger attached then either that the battery is dead and you need a new one or your laptop itself is gone
Dec 30, 2009 | Office Equipment & Supplies
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
