Question about Lorex 16 Channel 500GB Network Video Surveillance DVR with 4 Color Security camera
Do I need to connect my camera system to internet,to get it on my iphone?
    Problem Solver:
  • 23 Answers
Yes from ip address or from router
Posted on Dec 05, 2014
  • 2,760 Answers
NOT EXACTLY IF YOU WISH TO SEE IT ON YOUR PHONE FARTHER AWAY THAN 150 FEET FROM BASE THEN YES YOU HAVE TOO! IF NOT YOUR SMART PHONE HAS A SEARCH FOR WIFI NETWORKS IN IT';S APPS LOOK FOR YOUR MODEL NUMBER IN THE LIST IT FINDS
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
I set up my Surveillance system and I can view the cameras on my iphone at home but when I leave I can not?
Your phone is most likely connecting via Wi-Fi when you are home, but after you're out of range of Wi-Fi, your Surveillance System must be set up to give you access through the internet. The camera instructions should tell you how to set it up and the manufacturer probably has an app that you need to install on your iphone to access your camera system from the internet.
Sometimes setting up internet access is no easy task. You must open a web port on your router in order to send and receive the signal from your security system and communicate with the internet. Determine which port the security system is set to communicate with and open that port on your router.
There are so many different configurations for security systems and routers that it would be impossible to specifically lead you through each step. But I hope this general description will be helpful in getting you started.
Sep 17, 2013 | SVAT Home Security
I can't figure out how to get a reliable connection to the Internet through my iPhone 4.
Hi Mickie
The iPhone can connect to the internet in a couple of ways. What have you tried so far?
If there's a SIM card in the phone you should be connected through your service provider? If not, id there a wi-fi system where you are that you can use?
Feb 27, 2013 | Computers & Internet
Tether my iphone 4 for free
step 1 : From Home Screen select Settings
step 2 : Select General > then select Network
step 3 : Press Internet tethering to turn the function on
step 4 : Connect it to the PC using the USB cable or using Bluetooth
step 5 : Once handset is connected to PC , Select iPhone from the list of available connection using the Internet access icon in the system tray. Press connect and you'l be able to surf the internet using your device.
Apr 08, 2012 | Apple iPhone4 4G iPhone 4
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Opera Software Mini
Iphone 3g waps message
even if you're not using the internet, the iphone automatically connects you to the internet that's why it keeps on prompting you. try changing your settings so that you wont automatically connect to the internet.
Jul 26, 2010 | Apple iPhone 3G
Adding a device
Is your network a secured network?
Oct 08, 2008 | Westell Wirespeed VersaLink...
What do i need to do to delete the iphone photos ?
2 ways:
1. When you click "import photos" while syncing your iPhone it asks you if you want to keep the originals or delete them (meaning on the iPhone). Just click delete originals
2. Go into your iPhone and clear all photos.
Jun 09, 2008 | Computers & Internet
Lorex 16 Channel 500GB Network Video Surveillance DVR with 4 Color Security camera Logo
117 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
