Question about Brother MFC J220 - multifunction fax / copier / printer / scanner color
My mfc j220 doesnt print anything although the inks are full
Our printer doesn't print anything, although we clean it for how many times. we got the same results, it doesnt prin anything.what should we do?
SOURCE: MFC-440CN printing problem
i cannot print anything
Posted on Jun 03, 2008
  • 164 Answers
SOURCE: The printer is not printing although i already
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Daniel S
  • 4323 Answers
SOURCE: my printer is printing very
Hi
To solve this issue unplug the unit and take out the cartridges then clean the print head which is the area beneath the cartridges with a hot water towel, let it dry out for a while and see if it works again. If the issue returns then it seems that the print head is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 30, 2011
Geekman
  • 32281 Answers
SOURCE: my brother mfc j220 canoot
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Sep 06, 2011
  • 27 Answers
SOURCE: brother mfc-j220 printer always say cover is open
make sure the cover do not have any paper / items blocking the cover, place the printer on a "flat" surface, make sure your USB cable is not longer then 1.5Meters, try reinstall driver and try again, good luck :)
Posted on Aug 07, 2013
How to reset ink absorber full for brother mfc-j220
https://www.google.co.uk/search?es_sm=122&q=BROTHER+PRINTER+MFC-J220+INK+ABSORBER+FULL&spell=1&sa=X&ei=L7HgVMfAA5HLaJP-gJAD&ved=0CBwQvwUoAA
Feb 15, 2015 | Brother MFC J220 Multifunction Printer
Why does our brother mfc-j220 won't print after ink refill
Unplug machine and try again. Let it reboot from the start. It should sense the new ink.
Sep 23, 2014 | Brother MFC J220 - multifunction fax /...
Ink absorber is full in bother mfc-j220
replace the waste ink tank, then reset purge counter
Jul 25, 2014 | Brother MFC J220 Multifunction Printer
Unable to clean 5A for brother printer MFC J220
check for ink levels and also check for rollers and usb connections drivers etc
Apr 05, 2014 | Brother Office Equipment & Supplies
Ink absorber full mfc-j220
Remove the power source of the printer
Press the menu button .. Do not leave this button
Wait until you see the list of maintenance
wait a bit
Press 8
Okay
Press 0
Okay
wait a bit
Use the buttons START (Mono + Color) until it reaches the purge
Press this order figures
Okay
7
Okay
8
ok
ok
Wait until the value turn into zeros
Press exit
Press 9
Then 9
The printer will restart
End
EZZAT / EGYPT
Feb 18, 2014 | Brother DCP-J125 Inkjet Multifunction...
Ink absorber full brothers
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
The ink absorber box or flushing box will need to be replaced.
Other reasons for cleaning are:
  1. Machine automatically cleans after clearing a printer jam.
  2. Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
In Case Your Not Able To Clear Your Problem Then Go to Official Brother Printer Website: http://welcome.solutions.brother.com/BSC/public/as/hk/en/faq/faq/000000/002700/000051/faq002751_000.html?reg=as&c=hk&lang=en&prod=mfcj6710dw_all
Or
Still Having problem Then Follow Us For On:Brother Printer Support
Jan 23, 2014 | Brother MFC J220 Multifunction Printer
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC J220 - multifunction  fax / copier / printer / scanner   color Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
