Question about Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE
PCI bus 5, device 0, function 0
Intel i7 cpu 870 @ 2.93ghz
2 Suggested Answers
bhagyavichar
  • 414 Answers
SOURCE: My computer with Windows XP Pro SP2 is crashing
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 13, 2009
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
Computer memory issue...PLEASE HELP?????
Intel[R]G41 EXPress chipset[vendor id=0X806,device id=0x2e32]
Feb 16, 2012 | Acer Veriton Computers & Internet
RIPPING MY HAIR OUT TRYING TO FIGURE OUT WHAT KIND OF R.A.M. I NEED? I HAVE ORDERED 6 DIFFERENT CONFIGURATIONS AND STILL GET BEEPING NOISE AND NO POWER ON FOR COMPUTER. PLEASE SOMEONE OUT THERE HAD T
you lost me you have a g41 and mixed memory and e6700acer and beep start test power supplysame memory typego to tigerdirect memory configurer one stick close to cpu in swap out pound del key see if bios check outgo for match set
Feb 16, 2012 | Acer Computers & Internet
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
I82801@P4BGV-MX audio ctrler invisible in devmgmt.msc
open device manager and i m sure that it will be given under system devices because all the devices that does not come under
unidentified devices are in the system devices list check it there or instead use some software like driver detective to find all the devices connected to the computer and get their device drivers
Jul 08, 2009 | ASUS (P4BGV-MX) Motherboard
PCI bus 0, device 17, function 5
real tetak suod card driver chiya tha
intel 945gcnl ka bord hai
May 11, 2009 | Intel ESS ES1868F Sound Card
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Asrock H55M-LE LGA1156/ Intel H55/ DDR3/ A&GbE/ mATX Motherboard H55MLE Logo
14 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
