Question about Canon ZR10 Mini DV Digital Camcorder
Tape will not eject
I press the open/eject switch ,open the cover and the mechanism for the door moves up very slightly then back down.
  • 883 Answers
SOURCE: Tape wouldn't eject, now power unavailable.
open it. find the motor that activates the tape door. turn it by hand until tape is fully exposed to be removed.
Posted on May 31, 2007
SOURCE: Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Posted on Aug 16, 2006
Gryfox
  • 216 Answers
SOURCE: Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Posted on Dec 18, 2006
SOURCE: Door opens "Slightly"
I had the same problem, and TomInMB
told me how to fix it:
What I did was to first remove the battery and AC power to "reset" the camera. I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VOILA!
I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism. Good luck!
Walt D in LV
http://www.thecinemaniacs.com/
Posted on Jun 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ZR25MC, DV tape can't be ejected.
The best way to get it out is take it to a camera shop of Best Buy. They didn't put a manual eject on the player. If you take it into a shop they should know what to do.
Once it's out clean the heads with a DV tape cleaner.
Posted on Jul 13, 2008
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Can't open door - can't eject tape
How old is your camera?
Seems it has weak capacitors in circuit.
Oct 27, 2008 | Sony Handycam CCD-F555 Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
Tape rack stayed open
I just experienced the same problem, but it took me 10 minutes to get it working again. When you look inside the tape rack, you see on the left side in the middle a little mechanical arm which you can press down for about 1cm when you release it again the rack opens completely Good luck Robert
Jul 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
Canon ZR10 Mini DV Digital Camcorder Logo
91 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
