Question about Sewing Machines
Needle position stop
Change needle position stop brother 6000i
SOURCE: needle always stops in up position
I have the Activa 131 and while the needle is made to stop in the up position, all you have to do is push the bottom of the peddle quickly with your heel and the needle goes into the material and stays until you start sewing again. Hope this is helpful.
Posted on May 27, 2008
  • 323 Answers
SOURCE: needle position
this wheel does seize over a period of time.Remove the top cover so that you can see the wheel. It can be unseized by spraying a mixture of 20% ammonia to 80% water under the wheel. Let it sit for 20-30 minutes, spray it again and then turn it with a pair of pliers. Do NOT break it!! use a soft cloth around it if you want to protect the wheel from scratches.
sewman7
Posted on Jun 18, 2008
SOURCE: Brother pro 600 embrodiery machine
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Posted on Jan 04, 2009
SOURCE: Juki TL98Q needle thread breakage
Use a thread stand and rethread.
Posted on May 23, 2010
Joe Onley
  • 363 Answers
SOURCE: brother pe770 - needle threader is stuck in the
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or twice to raise the needle.
> The needle is correctly raised when the mark on the handwheel is at the top, as shown below. Check the handwheel and, if this mark is not at this position, press (Needle position button) until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
Posted on Sep 17, 2011
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
Feb 02, 2018 | Brother Sewing Machines
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
Needle hits the quilting presser foot
Needle may be slightly bent. Needle may not be properly or fully inserted into the needle clamp or holder. Needle may even have a burr on it or be too dull. Needles must be changed fairly often, especially with many of the modern synthetic fabrics. They do not last forever.
Change the needle first, for a new one, be sure it is properly inserted. Then, make sure you have not accidentally set your stitch width incorrectly. I've done that myself after using a zig zag stitch mode and forgetting to change it, or not change it all the way back to straight stitching.
Some machines will allow the needle to be set at centre, left of centre or right of centre, so be sure it's in the correct place for the stitch and foot you are using, or you will hit the foot.
Hope one of those turns out to be the right tip.
Oct 16, 2016 | Brother Sewing Machines
How to change needle position
Needle Positions on the SEWING MACHINE - YouTube
? 1:37
https://www.youtube.com/watch?v=OhN7w6DqX_Y
Oct 5, 2014 - Uploaded by Cindy Fetzer
8:52. How to Change Needle Position (filter bag machine) - Duration: 20:39. by Peter Wang 935 views. 20:39. BeginnersSewing Course - Day ...
Adjusting the default needle position, Brother PC 420 ...
? 6:53
https://www.youtube.com/watch?v=Xfq-GW88DsA
May 17, 2014 - Uploaded by Spamnot Nospam
Do you have trouble with the default left needle position making the needle of your Brother PC 420 sewing ...
Guide to Understanding Sewing Machine Needle Position
Jan 01, 2016 | Sewing Machines
Why does my cs6000i the needle hits the bobbin case put nicks in case and then thread snags in the bad area
If you are talking about the bobbin case (housing), it may be inserted incorrectly. Remove it and put it in again, or the needle isn't seated correctly. Once the bobbin case is damaged, do not use it anymore or you will continue to have problems. If you mean the bobbin, change bobbins and see if you continue to have problems, as you might have the incorrect size.
Jun 27, 2014 | Brother CS-6000i CS6000i 60-Stitch...
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
E6 message on brother CS 6000i
Needle Position Sensor is disconnected
This sensor detects the drive timing for the pulse motor for
zigzagging and feed, the vertical stop position for the needle. It
detects the upper shaft angle of rotation using a shutter attached
to the upper shaft and an optical sensor.
See HERE for Service Manual
Nov 10, 2011 | Brother CS6000i Computerized Sewing...
Brother cs 6000i squeaking
By any chance were you using your walking foot when it was squeaking? I had the same issue and realized it didn't squeak unless I was using the walking foot, it was actually the walking foot that was squeaking :D I can live with that!
Sep 02, 2009 | Brother CS-6000
Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
Jan 29, 2009 | Brother CS-80
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
