Question about Epson Artisan 835 Wireless All-in-One Inkjet Printer
Communications error between Windows 8.1 computer and Artisan 835 scanner
I have an Epson Artisan 835 printer/scanner and new Windows 8.1 computer. The printer is connected by wireless network to computer. Printing function works great between computer and printer. I can scan from printer/scanner to computer but not from computer like I used to do with my old Windows XP SP3 computer. I keep getting communications error with my new computer. What's wrong?
    Problem Solver:
  • 10 Answers
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Posted on Jul 23, 2016
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan  on IMac with Epson Stylus CX3900?
Posted on May 15, 2009
  • 1218 Answers
SOURCE: EPSON 9600
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
SOURCE: My new Epson Artisan 835 Printer is supposed to
Yes.
Posted on Oct 21, 2010
SOURCE: Hooking up Epson Artisan 800 to wireless. Get all
You must set both devices to the same encrypryption protocol, WEP or WPA. That being said, I had to setup my router using WEP - the printer refused to connect via WPA. Good luck.
Posted on Jan 26, 2011
SOURCE: I am unable to scan
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Posted on Feb 05, 2011
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
What printers will take espon ink cartridges 99
The products that uses the T099 ink cartridges are the following:
  • Artisan 700
  • Artisan 710
  • Artisan 725
  • Artisan 730
  • Artisan 800
  • Artisan 810
  • Artisan 835
  • Artisan 837
Sep 07, 2014 | Epson Office Equipment & Supplies
Epson 835 printing only the top of the page being copyed
1. In Internet Explorer, try going to : 'File', 'Page setup' and check off the box for 'Print Background Colors and images'.
If does not work, go to:
2. In Internet Explorer go to 'Tools', 'Internet Options', go to 'Advanced' tab then go scroll down to 'Printing' and make sure box is checked for 'Print Background Color and images'.
3. If still not working, advise, you may need to take your ink out and use a syringe and mineral spirits to clean the heads of your printer (lots of times these get clogged).
4. All else fails, you can set your printer back to default settings, can find out how to do that over the internet.
One of these will fix your problem.
Jan 24, 2014 | Epson Artisan 835 Wireless All-in-One...
I get the message "printer error has occurred" and please turn the printer off and on repeatedly with no change. This is the Epson Artisan 835
My Epson Artisan 810 repeatedly would give me the printer error message with the only option to turn off the unit and turn it on again. Over and over it would give me the printer error message. With the unit off, I opened the cover (like you would to replace the ink cartridges) and forced the CD tray all the way out like you are about to load a CD for printing, closed the cover, then started the unit up again. For me that did the trick. It went through it's normal 60 seconds or so of set-up, then worked fine ever since. Not sure if this will work for you, but it worked for me.
Dec 29, 2012 | Office Equipment & Supplies
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
I have bought an Epson Artisan 835 printer & can't get it to connect wirelessly to a Billion Router (BiPAC 7300G).This router is connected wirelessly to my i-Mac. I currently have the printer...
1) Please check your router setup whether it does not allow Wireless devices to ping against each other;
2) If it does not allow to ping (communicate) with each other, please disable it first.
3) Then please check your Epson wireless setup whether the DHCP function is enabled; if not, please enable it;
4) Please also input your network gateway, sub-net mask correctly into the Epson printer, otherwise the wireless communication with your network will not work.
5) Then switch off your printer and turn on again to recognize the new settings; and it should work
Aug 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Jan 10, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 835 Wireless All-in-One Inkjet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
