Question about Maytag Dryers
Squeaking Loud squeaking noise
  • Maytag Master
  • 2,180 Answers
Most likely the belt pulley or a roller,send the model number next time
Posted on Feb 13, 2014
  • 132 Answers
SOURCE: dryer making loud squeaking noise
Replace all the drum rollers.
Posted on Mar 26, 2009
  • 61 Answers
SOURCE: loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Posted on Jun 09, 2009
  • 479 Answers
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Posted on Aug 11, 2009
heatman101
  • 43501 Answers
SOURCE: Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Posted on Sep 29, 2010
  • 250 Answers
SOURCE: loud squeaking noise hotpiont dryer
either the remainder is worn our the wheels that the drum spin on or the belt is slipping
Posted on Feb 02, 2012
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
2000 Nissan Pathfinder, makes loud squeaking noise while driving between 0-35mph, bought a new timing belt a year ago and had AC belt replaced recently, squeaking is so loud it is almost disturbing to...
Very often the power steering belt can cause this noise if it is loose or just worn. The pump itself can cause a noise check and make sure it is full of fluid.
May 06, 2014 | Cars & Trucks
Loud squeaking noise hotpiont dryer
Feb 01, 2012 | Hotpoint Dryers
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Theres two belts, I had the same problem, replaced the other one and it went away.
Dec 27, 2008 | 2000 Chevrolet Metro
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
