Question about Frigidaire Affinity ATF7000E Front Load Washer
E44 error code on frigidaire - Frigidaire Affinity ATF7000E Front Load Washer
2 Suggested Answers
  • 630 Answers
SOURCE: I have a Frigidaire affinity front load dryer that after seconds will stop and show error code e44. What does that mean and how do I fix it?
E44 is an error code for the control board.
Posted on Aug 30, 2016
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
My zanussi washer is coming up with error code 40 anyone no what it is
Dado
Aug 27, 2015 | Zanussi Washing Machines
How to do with E40 code of Electrolux EWF 1074?
programme):
E41 - Door open
Possible causes:
Dado
Aug 24, 2015 | Electrolux Washing Machines
What does e44 means
you will have to google the make/model error e44 to find that out as we have no info from you
Mar 10, 2015 | Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
E44 = ?
Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
May 08, 2013 | Electrolux Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
