Question about Dimplex DS5629 Electric Heater
Wont blow then gets hot and turns of - Dimplex DS5629 Electric Heater
When i turn on the ac the transformer fuse will blow
If you are blowing a fuse just when you turn on the ac then the anomaly has to be with a circuit that only operates when AC is turned on. How about the compressor clutch which is electrically operated? If hot wires going to that unit lose insulation and get grounded, then the moment you turn on the Ac you will have a short and the fuse will blow. Or maybe the clutch has developed an internal short.
Nov 24, 2013 | Dometic Rooftop RV Air Conditioner
Heater wont blow hot air
how old is the thermostat? are any hoses cracked or sucked together. heater core may need to be flushed or replaced? good luck!
Oct 20, 2013 | 1994 Ford Ranger Supercab
My 1998 malibu runs hot when not moving, and now the heater wont work
Does the engines electric cooling fan turn on when it gets hot? Does it cool off if you turn the AC on?
Feb 24, 2012 | 1999 Chevrolet Malibu
Why my ac in my cadillac deville 1996 blows hot air?
If your low on freon then the A/C wont come on? for a 1996 you will need to get it serviced if you havent its normal to loose 10% freon a year,
May 06, 2011 | 1996 Cadillac DeVille
When I turn on the air conditioner it is blowing hot air as if the heater were on. Could it be a fuse? It was working fine yesterday.
heater core is going bad my dodge ram truck did the same thing for about three months then steam startedcoming out of the vents it was antifreeze i have not fixed it yet i just bypassed it for now cause its hot and i have to take the dash completly out to get to it, and yes my airconditioner was blowing out hot now immediatly after i bypassed it blows cold again.you have to find where it goes into the motor on both sides so follow the hoses from firewall then buy a 3ft hose to go from one side of motor to the other problem fixed! well that is you wont have a heater until you change the heater core
Jul 07, 2009 | 1999 Mercury Sable
Heater won't blow hot air
you may need to change your thermastat
Dec 11, 2008 | 1998 Plymouth Breeze
Dimplex DS5629 Electric Heater Logo
19 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
