Question about UPPAbaby GLiTE Stroller
Plastic tab clamp that fastens to hold stroller in folded up position broke off
Looking for a replacement for the folding mechanism of a p&t vibe 1
Hi
I was wondering what side clip you are missing???
It has been ages since you have posted, not sure if still searching???
Nov 30, 2012 | Regal Lager Phil & Teds Vibe Jogger
How do you fold down the valco runabout trimode stroller? I bought a used model and I can get the top half to fold over but that's it. Can it fold over more compactly? I'd like to travel with it. Thanks!
hi!!
to fold the stroller yo need to:
1.fold the hood back up against the handle.
2.release the locking clamps at either side of the stroller.
3.simultaneously lift the secondary safety catch and swing the handle forward.
4.holding the frame at the rear, press down on the rear basket tube.
5.you also can lock the frame with the strap next to the frame.
here you have the manual, could be easy with de graphics!
http://valcobaby.com/uploads/tx_productcatalog/Tri-mode_2007_Instructions.pdf
hope to being helpful!!
(if so, dont forget to rate me!)
Sep 25, 2010 | Valco Runabout TriMode Single - Stone...
I can not fold my bebecar raider at stroller
Firstly, remember to lock the swivel wheels in the non steering
mode before folding chair.
To fold, firstly press the red button and simultaneously, turn the handle collar in the direction of the
"FOLD" and the chair will begin to close.
Operate the secondary safety device by pulling the plastic tab.
Tilt the chair forward and continue the folding action until the chassis is fully closed. Why not ask for a user manual at service@bebecar.co.uk
Aug 25, 2010 | Bebecar Raider AT Stroller
Maclaren triumph stroller hood broke
Listening to what you have described, it sounds as if the hood clamps have snapped, this does mean a new hood most of the time.
I would suggest that you contact Maclaren at their website, or go to the link below, input your postcode into it and locate the nearest authorised Maclaren Service Agent who will be able to look at it for you.
I hope this helps.
http://www.maclarenbaby.com/gb/component/option,com_wrapper/Itemid,88889245/lang,en/
Sep 14, 2009 | Maclaren Triumph Umbrella Stroller
How do i fold it
There is 2 clamps on side that open up right by the bumper bar,you open them up,undo the red clamp thing and push the stroller forward it has to be in up position then kick the basket to make it fold,then you can close it with a strap.
Aug 21, 2009 | Valco Baby Tri Mode Jogger Stroller
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
Laying Down and Folding Maclaren Triumph Stroller
Folding takes some getting used to, broke the first one I had because I used force. Here are some step by step instructions...http://www.strollerreviewguide.com/how_to_unfold_and_fold_maclaren_stroller_step_by_step
-Good Luck!
Feb 10, 2009 | Maclaren Triumph W0806063 - Navy Umbrella...
Can't get the stroller to "lock" in open position
well, to you all fellow combi stroll users: when the stroller is open, to fold it up, you pull up on the side black tabs, like a syringe, using index and middle finger. then manually rotate the lateral edges of the top push bar, and it will fold into itself. then the black locking bar should meet up and click into the front middle locking tab. this is what locks it into place to keep it folded up. and this is what must be released in order to open up the stroller. once the release bar is pushed up, the stroller should unfoled and just "pop" into place. babys r us sells this product, so i'm sure an employee can demonstrate as well.
Aug 14, 2008 | Combi Flare Umbrella Stroller
UPPAbaby GLiTE Stroller Logo
Top UPPAbaby Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you an UPPAbaby Baby Gear Expert? Answer questions, earn points and help others
