Question about Tamron Sp 500mm F8 55bb Adaptall 2 Telephoto Mirror Lens
Tamron 500mm mirror
Focus
Cant reach the center of the lens for fungus cleaning...
Are there two nested tubes involved? Male to female threading?
Feb 25, 2014 | Vivitar 500mm f/8.0 Mirror (Reflex) Manual...
How to clean the fungus off a Mirror on the inside of a 500mm Mirror lens
Unless you have a lens collimator and other gear needed to make sure you get the lens and mirrors aligned properly when you put it back together, don't even think about taking it apart. Take it to a reputable camera shop and have a trained professional do it.
Jan 30, 2013 | Samyang 500mm f8 Ultra Telephoto Manual...
I will be traveling to Africa in November. I have a Tamron 200-500mm lens that I will be using with a Nikon D90. I would like to use a beanbag when taking my pictures from our tour's vehicles, which...
It's not impossible. You can either focus the lens before setting it down onto the beanbag, or go ahead and set it down and then let it focus. In the latter case it may try to slide to one side or the other, but you should be able to hold it in place. At home, set the lens down on a pillow or a sofa cushion and try it.
As an alternative to a beanbag, consider something like the ThePod, which screws into the tripod socket on the lens. http://www.thepod.ca/
Aug 03, 2011 | Tamron 200-500mm f/5-6.3 Di LD IF Lens
I have a tasco 302911 D+114mm F+500mm telescope
You are NOT focused properly. Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow if you have one.
Go outside during the daytime and practice focusing on a distant object. Turn the focus knob back and forth slowly until the image is in sharp focus.
Jun 02, 2010 | Tasco Galaxsee 46114500 (500 x 114mm)...
I have 500mm mirror len with canon EOS mount. Can
Maybe you're trying to get it to focus on something too close.
Feb 03, 2010 | Cameras
Soligor mirror 500 on Nikon D-80 ????
The D80 is not able to set exposure with non-CPU lenses like your Soligor, so it probably is very far off on the correct exposure. You must operate in Manual mode and choose a shutter speed appropriate for the lighting. Reflex (mirror) lenses have no aperture adjustment, and I'm guessing your Soligor 500mm is probably f/8 like just about every other 500mm reflex. A good starting exposure for a typical sunlit scene would be 4x your ISO setting. For example, at ISO 400 set your shutter speed to 1600.
Mar 08, 2009 | Samyang 500mm f8 Ultra Telephoto Manual...
Vivitar telephoto lense 500mm
Yes and no. If it doesn't come with one, you'll need a T-adapter for Nikon in order to mount the lens (you can get one from Vivitar, as well as from other manufacturers). The lens is not an autofocus lens, so obviously you will have to focus manually. It's also a mirror lens so it has a fixed aperture. It's what Nikon classifies as a non-CPU lens, so you cannot use the D90's exposure meter. You will have to shoot in Manual mode.
Feb 18, 2009 | Vivitar Telephoto 500mm f/8.0 Mirror...
500mm lens will not function with my Canon digital Rebel XT.
This lens will work with Canon cameras. I use one on my Canon 30D. It is a fixed F8 you can not use auto or green box because there are not any contacts on the lens to talk to the camera. Its back to the basics manual adjust shutter and ISO to the get a correct exposer. DEFINITLY NOT A POINT AND SHOOT LENS.
Dec 11, 2008 | Quantaray 500mm f/8.0 Mirror with Macro...
Pheonix 500mm lens
I assume you are speaking about the 500mm mirror lens. They work well but don't have any depth of field so focusing must be accurate to get a good image.
Feb 13, 2008 | Cameras
Tamron Sp 500mm F8 55bb Adaptall 2 Telephoto Mirror Lens Logo
16 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
