Question about Avanti FFBM920W
HAD THIS BOMB FOR 2 YEARS THE FIRST MONTH THE FAN WENT DEAD SO THE GUY CAME AND FIXED IT THEN 3 MONTHS LATER HE FIXED IT WIT A NEW FAN THE NEW PROBLEM NOW IS EVERY 12 HRS OR SO IT STARTS MAKEING A LOU
I HAVE THEAVANTI FFBM920W FOR 2 YEARS THE FAN WAS CHANGED TWICE.THE PROBLEM IS EVERY 8-12 HRS ITS STARTS TO MAKE A LOUD WINEING NOISE SO I PULL THE PLUG FOR A FEW HRS AND IT RUNS FINE UNTIL ITS TIME TO UNPLUG IT SINCE THE FAN WAS CHANGED 2 TIMES IT MIGHT BE THE FAN ALSO THE SEAL ON THE FREEZER DOOR CAME LOOSE SO I RE GLUED IT I ALSO USE TAPE TO KEEP THE DOOR TIGHT IT STILL KEEPS ALL THE FOOD COLD AND THE FREEZE IS FINE.
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
aasc
  • 1606 Answers
SOURCE: shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Posted on Aug 26, 2009
ailia
  • 175 Answers
SOURCE: I have an Avanti outdoor refrigerator. It's about
Try to place on flat ground surface, u can balance its weight. Check compressor fan if its making noise.
Posted on Nov 05, 2009
  • 15 Answers
SOURCE: the inside of the refrigerator is not staying
If any part of the automatic defrosting system isn't working, the evaporator will turn into an iceberg and no cold air will circulate into the lower compartment.
Possible causes in that case could be the defrost timer, the defrost thermostat ("bimetal"), the defrost heater, the defrost thermal fuse (if there is one), or the wiring and plugs connecting them.
Removing the back panel of the freezer compartment should reveal the iceberg and allow you to defrost it with a hair dryer or fan. Then you can get at the parts to test them (except the defrost timer, which may be down by the compressor).
Posted on Dec 15, 2009
  • 266 Answers
SOURCE: Hi, I have a WCR524SDZD wine
your unit uses a generic fan motor that a lot of refrigerators ect.. use. If you take the fan to a local shop that sells refigerators they will match up one for you. Avanti's phone number is 1 800 220 5570. good luck
Posted on Aug 11, 2010
Ford cougar clutch replacement 3 times in less than 3 years
you get a 12 month warenty with any clutch same as fitting if you going through that many clutches though did any one check the flywheel if its a duel mass fly wheel it could be damaged or groved causing the clutch to wear more quickley also the input shaft could be worn or warped or thebearing could be going causing movment i would go with fly wheel but i would have hell on if id paid for a job which is not cheap and its either never been done properly or they have used rubbish cheap parts you can go to traid and standards if your from uk or whatevers the equivelent abroud and send him a letter asking him to replace it free of charge i wouldent let it go though hope this helps ivan uk
Oct 08, 2012 | Cars & Trucks
2000 chev silverado 1500 5.3 liter alternator keeps going bad
i believe there are 2 alternator's for that 5.3 i think you need the one with the higher amps. I had the same problem and went with the higher amp alternator and i have not had a problem that was 3 years ago.
Jul 12, 2012 | 2000 Chevrolet Silverado 1500
Did these N200 0769 have a lot of faulty motherboards, my first Mboard failed within guarantee- and has again failed within 9 months of replacement.
I have a Lenovo 0769 and my motherboard is dead, it worked for 2 years and 3 month. Now it is out of warrenty and new motherboard costs almost the same as a new laptop..
Jan 04, 2010 | Lenovo 3000 N200 Notebook
Intermittent dead ignition to dead ignition
This problem is usually caused by a failing neutral safety switch. Try moving the shifter when it is dead. Will it start in neutral? Move the shifter while trying to start (foot on brake!)
Jul 14, 2017 | 1991 Acura NSX
Fan always running
vacuum out air ports/power supply fan or use compressed air in a can to clean out dust.
yes this is bad, life is greatly reduced.
clean dust out once every other month or as needed.
Oct 02, 2009 | Computers & Internet
Apparently leakage has come out of the tubes and
Yes its a very common in Samsungs to leak CRT coolant onto the boards that drive the CRTs. Most repair techs will automatically check for leaking CRT coolant on Samsung and mitsubishi simply due to their history of that problem.
Aug 21, 2009 | Samsung PCH521R 52" Rear Projection...
Power Problem
your ps3 is dead this si similar to the xbox360 red ring of dead some ps3's can be fixed some not there is a guy on ebay who does this type of job go to ebay and enter the world ps3 reflow and you will see like 2 diferent guys there
May 12, 2009 | Video Game Consoles & Games
Keyless remote only works part of the time.
I had the same problem only a few months after I bought the car new in 2003. Dealer fixed it. Then 6 months later same deal. Finally I went to a 3rd party and ordered new different brand remotes and figured out the programming which was quite simple. A serirs of procedures with the door and the key which programmed the devices. 5 years later no problems. Of course before you do anything try replacing the battery in the remote.
Mar 09, 2009 | 2003 Suzuki Aerio
Vacuum cleaner blew the fuse in my house!!
Are you sure that the vacuum motor went bad? If it did, then if would just have to be replace again. Doubt that you would find a different motor other then what belongs in there. If you did it would have to the right size to mount right. Some motors will last a long time while others just don't and you never know how long a one will last. Maybe the power head is what caused your present problem.
Jan 12, 2008 | Vacuums
Avanti FFBM920W Logo
15 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
