Question about LG BD550 Blu-Ray Player
When dvd inserted no video on the screen displayed
When i plug my AV coil in my philips TV the screen goes dark
If the DVD player is playing and you have the Scart lead plugged in, check what the playback system is, Your TV is probably Composite Video and the DVD player may be set to RGB for example.
Mar 14, 2014 | Televison & Video
Set-up for portable DVD player by Craig cmd420
Hello
[1] Insert the batteries into the Craig DVD player. Depending on the model you are using, the batteries are either rechargeable lithium-ion batteries or store-purchased AA batteries.
[2] Plug the 3.5mm cable into the headphone jack on the side of the Craig DVD player
[3] Insert the opposite end of the cable into the "Aux" connection on the car stereo. Without this audio-input option, you will be unable to hook the Craig DVD player up to your vehicle.
[4] Power on the Craig DVD player and insert the desired DVD. The video will load onto the display screen while the audio is played through the car's stereo system.
[3]
Oct 18, 2011 | Craig 731398407019 Portable DVD Player
I want my player to play dvd while driving how do i bypass to make this possible
  • 1st you will need to purchase a 12 volt or above Momentary Push Button/(Toggle)switch (about $5 Radio Shack)
  • 2 2nd Using the Diagonal Pliers adjust the length of the Radio's Emergency Brake Wire to your desire. Make sure you have enough wire so you can mount it where you can easily access it like beneath your steering wheel/ on the Dash Board.
  • 3 3rd Connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. Make sure you wrap up the wires using the Electrical Tape to prevent shorts.
  • 4 4th (Using Button Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the button (4x Times)for one second and release it. On The fourth time the screen takes about 6 second to display the video.
  • 5 5th (Using Toggle Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just flip the swtich on and off (4x Times). On The fourth time the screen takes about 6 second to display the video.
  • 6 Now your Passengers can enjoy the ride & Movie!!
  • Sep 29, 2010 | XO Vision XO9013 Car DVD Player
    No video from dvd
    You could possibly have a faulty set of RCA cables. Happens all to often. Change your RCA cables (Red,White,Yellow). And make sure they are inserted good. If problem still presists. you could have a short in your inputs on either you dvd player or your t.v.
    Aug 31, 2009 | Marantz SR-5200 Receiver
    Can't get the DVD player to wok in my 2006 Lexus GS300
    Repair Procedure
    1. Confirm the customer's complaint of DVD RSE system inoperative.
    2. For vehicles with Lexus Navigation System, perform the following procedure to turn OFF the RSE Lock function:
    A. Press the INFO button to display the "Information" screen on the navigation unit.
    B. Press the "Screen Setting" touch button on the navigation display.
    C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display.
    D. Press the DVD switch on the RSE system, (If a DVD is NOT already in the player, insert one) and confirm screen is "ON" and the system will play DVD's.
    3. For vehicles without Lexus Navigation System, perform the procedure to turn "OFF" the RSE Lock function.
    A. Push the audio control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "Rear Lock" is shown on the screen.
    B. Turn the audio control knob so the display says "OFF" next to "REAR LOCK".
    C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one.) and confirm screen is "ON" and the system will play DVDs.
    4. If the above procedure resolves the concern, explain the system operation to the customer. This procedure is described in the "Audio/Video" section of the vehicle owner's manual.let me know lf this helps.
    Jun 14, 2009 | 2006 Lexus GS
    The DVD tray does not open
    I just unplagged it for a few hours and then it just worked prorerly again
    Mar 02, 2009 | LG RC185 DVD Recorder/VCR
    Trouble viewing DVDs
    I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
    Oct 07, 2008 | Televison & Video
    Dvd function not working
    PS is progressive scan, unless you have the player hooked up to a HDTV on its component inputs it wont play video, you need to locate button either on the front of the unit or on the remote for the Progressive Scan, this might be a good thing to look up in the manual as I dont know much about this unit.
    Jul 07, 2007 | Daewoo DV-6T955B DVD Player/VCR
    LG BD550 Blu-Ray Player Logo
    11 people viewed this question
    Computer Repairing
    Computer Repairing
