Question about Plumbing
How do I remove the handle on a Pegasus kitchen single lever faucet to change the cartridge ?
  • 148 Answers
SOURCE: leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do i remove a single handle kitchen faucet
    There is typically a cover plate that needs to be pried off. Under it you will find a screw that needs to be removed. Other types use a set-screw that would be visible at the base of the handle.
    Aug 07, 2014 | Pegasus Technologies Pegasus Kitchen Sink...
    Why no water thru delta single lever kitchen faucet
    can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
    Mar 25, 2013 | Delta & Single Handle Shower Faucet
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Kohler Fairfax single control kitchen sink faucet
    Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
    Good Luck and please rate 4 thumbs up for the free answer.
    Mar 19, 2010 | Kohler Fairfax Single Control Lavatory...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    Low hot water pressure in kitchen faucet
    I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
    Oct 14, 2009 | Moen & Replacement Cartridge
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    Single handle pegasus kitchen faucet. No water pressure when turn
    Kitchen faucet? Remove the internal parts and check for blockages.
    Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
    Plumbing Logo
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
