Question about PfaFF Tiptronic 2040
Change 220v to 110v - PfaFF Tiptronic 2040
  • 3,961 Answers
You will need a transformer. If the appliance is 220V to start with, you need a step-up tranformer, that is, 110V supply UP to 220V output. The other way round, a step-down transformer.
They are sold at hardware outlets and electronics suppliers like RadioShack.
Posted on Feb 13, 2014
Can i convert a pfaff select 4 from europe (220V) to 110V?
Aren't there converters available for people who travel?
Oct 08, 2015 | PfaFF Sewing Machines
Voltage change 220v 240v
Your User Manual will probably have the information you require....r contact Husqvarna with a model number and ask direct.
More info is always helpful
Jan 15, 2014 | Husqvarna Sewing Machines
I accidentally plugged in my 110v portable sewing machine to a 220v outlet and it sparked
You have damaged your machine. Place it into the bin and go buy new.... or maybe if you are lucky you can find someone who can fix it.
Nov 25, 2012 | Sewing Machines
110vsinger portable sewing machine was plugged in 220v
Think about it. You burned it out by doing that. Happens quite a bit here in RV (caravan parks) which are supposed to be wired 110v 30 amps but get wired at 220v by a stupid electrician. It's hosed, dump it in the bin... or maybe sell some of the parts from it. and go buy a new machine.
My sewing has a 110 volts, but i plug in at 220,wht should i do?
Buy a converter transformer - this will convert the 220v mains to 110v. They are also used as safety isolation transformers on construction sites but cheaper, domestic, transformers are also available for household appliances, but first check the power consumption of your sewing machine by looking at the specification section of the handbook and make sure you purchase a transformer with at least 50% extra power rating.
Jun 28, 2012 | Brother LS-1520 Mechanical Sewing Machine
My name Devi from Jakarta , Indonesia, I was buying sewing machine Brother CP 7500 from amazon, i just want to make sure, in indonesia voltage is 220V, how about CP 7500 ? is the voltage 110V or 220V ?...
Amazon is in USA so item would probably be 110 V and not suitable for you. You need to buy a machine locally or from Australia with same voltage as you, 220V. If you try to use a 110V machine you will fry the engine and electricals.
You should be able to buy the same model, just buy it in your voltage.
Jul 26, 2011 | Brother CP7500 Sewing Machine
I have an error code on my juki ddl 8700-7 that reads e811
hi there
may i know control model ? any way E811 means :
1- over voltage when voltage higher than guaranteed one is inputted ( please check wheter the applied power voltage is higher than te rated voltag ( plus ) 10% or more.
2 - Check whether 110V/220V changeover switch is improperly set.
3 - if 400 volt is input means POWER P.C.B is broken maybe repair or need to change.
best regards
ashraf abozid
aaboid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
Power range / watts for Elna 6005 sewing machine
There will be a sticker or engraved fine print next to the power socket or on the bottom of your Elna that will say what voltages it is compatible with. If it says 110v/220v you can use a plug adapter.Note well that the adapter doesn't change the voltage in anyway it just makes the plug fit. If it only says 110v which is most likely get an AC to AC adapter, **** Smith Electronics or Tandy will be able to help. If you're unsure don't take the risk it will take a second to destroy the electronics if you use the wrong voltage!
Jan 08, 2009 | Elna Heirloom Edition 6005
How to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Aug 01, 2008 | Brother Sewing Machines
Sewing Machines Logo
140 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
