Question about Reddy R60A Utility Heater
Fan motor wont start
Where can I get a new fan motor part number 154037 A, for a lawn boy PH 150 heater?
3 Suggested Answers
tbugger
  • 232 Answers
SOURCE: HAVE OLD LAWN BOY 150
There are a number of things that will cause the symptoms described. From as simple as water in the fuel to a more complex problem such as a defective Ignition Device (transformer, Spark box).
You will need to read & follow the tips attached and attempt to narrow the problem down.
Troubleshooting tips
Posted on Nov 06, 2010
tbugger
  • 232 Answers
SOURCE: my heater is not getting
Lawnboy? Man, that thing is old! Keep it running cause they don't make 'em that good anymore.
Check to see if the Ignition Device (transformer, spark box) is getting 110v. This box must have a good ground to the frame. If not, the unit will not produce a spark at the plug. If it does have a good ground, then the part must be replaced. The current replacement part is 102482-01
Posted on Nov 13, 2010
Needing fan motor part. No online suppliers have any and can't get ph number of company
if your machines mfg has left the planet, and if your real insistent on fixing it , you can try to match it up via physical description , try a company called grainger.com they have lots of motors , but you'll have to search by physical description as they wont have any idea of what motor you got by model number
Feb 03, 2016 | Dehumidifiers
Why would a torpedo heater fan turn backwards? every time I start my all pro 115,000 heater the fan starts to spin counterclockwise and the heater wont ignite. But when manually spin the fan blade clo
If the fan has a 'run' capacitor, in rare cases, a faulty capacitor will cause a single phase motor to start in reverse. In most cases a faulty capacitor will cause the motor to only hummmm and not start or start slowly running the right direction then overheat and shut off.
See if there is a capacitor, change it first. If that doesn't fix it it sounds like its time for a new motor.
Nov 18, 2014 | Heating & Cooling
I have a Lawn Boy 10685 with a Tecumseh motor will it run with rear mulch switch off and either wired together or left open?
If you are getting spark, it should run, usually safety switches connect to ground out the coil to give no spark.
Apr 17, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Lawnboy 6.5 b and s motor was backfiring loudly when trying to start now when engine runs and heats up it cuts out and will not restart any ideas??? ran fine for a year and a half.
you need a valve job and have a unseated intake valve might have to get new motor if cant seat valve have to take to shop if cost 3rd by new mower
May 15, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
HAVE OLD LAWN BOY 150 BTU HEATER WONT STAY FIRED EVERY THING ELSE WORKES JUST WONT STAY BURNING ON AND OFF AS FAR AS THE BURNER
Nov 05, 2010 | Reddy R60A Utility Heater
190cc 3in1 briggs and stratton mower wont start... new plug and good spark..any ideas..
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Apr 24, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
PH55 "lawn boy" porta- heater need parts
Lawn Boy sent me an 800 number for the company they sold the heater line to.
800-362-6951 portable heater parts. I have not called yet to find out if they will have qhat I need. Will call tomorrow, Tuesday.
Steve
Jan 25, 2009 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
