Question about Lowrance X67C Ice Machine with PPP-18I kit
Screen shows lines only, lowrance x67c - Lowrance X67C Ice Machine with PPP-18I kit
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
HDs 8--detecting bait fish?
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Feb 06, 2013 | Lowrance HDS-8
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
Lowrance HDS 5 Sonar faulty
You realise we are FIXYA, we are not Lowrance?
Is this when you are moving, or when you are stationary? If it is stationary, then the transducer or the wiring to it, or the plug into the head is faulty.
If it is only when you are moving, the transducer is not sitting at the correct angle and you are getting a disrupted water flow over it.
The other possibility is that you have the sensitivity set too high, which shows more activity on the screen. Set the head back to Defaults.
Feb 11, 2018 | Lowrance Hds-5 GPS Receiver
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
No image in my screen
When you ask for help, give make and model number. In this case, if display is a CRT type (cathode ray tube, not LCD), then a horizontal single line in the center of the screen indicates a lack of vertical deflection. If it is a vertical line in the center of the screen, it is a lack of horizontal deflection. Both problems can be caused by any number of components, all internal, and requires a technican to repair. Lowrance has a fixed fee system for their factory repairs. See their online info for support: http://www.lowrance.com/en/Support/Service-Information/Service-Rates/
Sep 30, 2009 | Lowrance Boating
First time run, everything mounted correctly, power on, no depth or sonar return.
So the depth is flashing and you don't see any bottom return at all, right?
Are you in the water, or trying it out before you put the boat in the water?
If you are not in the water, try it out in the water because it can be difficult to get any kind of return out of the water.
Try resetting the X67c to factory defaults:
1. Turn unit off
2. Press and hold the down arrow key
3. Press PWR while still holding the down arrow key, the unit will enter production test mode. Let go of the down arrow key
4. Press EXIT 5 times
5. Press ENT and the unit will shut off
Turn it back on and if you still have the same problem, depth flashing 0.0 or 0.5 or 60 probably and no bottom, then a good bet would be a bad transducer.
Jul 13, 2009 | Lowrance X67c Deep Water Color Sonar...
I cannot bring up a marine chart showing depth and markers on my
Marine maps must be installed on SD cards. The base-map does not contain marine maps. Most on-line or brick-and-mortar hunting/fishing stores carry map cards for Lowrance units.
May 28, 2009 | Lowrance iFinder Expedition C Handheld GPS...
Lowrance X67C Ice Machine with PPP-18I kit Logo
29 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
