Question about Vizio VBR220 Blu-Ray Player
Vizio blu ray will turn on but there is no signal displayed
No signal displayed on the tv screen
  • 16 Answers
SOURCE: our vizio blu ray player
Please inspect the HDMI connector on the back of the Blu-Ray player to make sure none of the pins (top and bottom) are not push back inside the connector. If there are return the unit for a another unit.
Posted on Feb 24, 2011
muntejaya
  • 10421 Answers
SOURCE: what is my code to hack the multi-region on my
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__hytg34
Posted on Feb 27, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
t407803
  • 84 Answers
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Posted on Apr 11, 2011
Testimonial: "This site was extremely helpful. Received resonse very quickly."
leethedeuce
  • 4472 Answers
SOURCE: i have a vizio vbr220
I would try and update the firmware and see if you can get that to work. How old is the player and did you buy it new. If you nothing works I would have it repaired under a 1 year warranty.
Thank you,
Lee
Posted on Jul 27, 2011
My Vizio blu Ray player displays a pink screen. What to do? I am using an Hdmi cable and Time Warner HD box.
You hook up your Blue Ray player to your TV using the HDMI cable, not to your cable box.
Jan 12, 2015 | Vizio Televison & Video
Vizio vbr220 says no signal
Ok. I know this is rudimentary but did you make sure that your tv input is on hdmi? Also you may need to go to the menu on the player and see if there is a output selection. Check to see how many input hdmi your tv has and check each one to see if that helps. Also check with different hdmi cables because sometimes it is that.
Jun 26, 2014 | Vizio VBR220 Blu-Ray Player
Vizio blu ray player
Have you tried a different hdmi jack, or a different cable?
May 05, 2013 | Televison & Video
How to program a new vizio 0980-0306-0940 to a vizio blu ray dvd player
This remote control has no setup codes for Blu-Ray player. available codes to blu-ray players are published by the linked site here. visit the site named 'Electro-help'. Click this link. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 18, 2012 | Vizio New Original 0980-0306-0940 Remote...
How do you reset a vizio blu ray player to default?
Find System Settings on the Main Menu. Under System Settings there is an option to Reset To Factory Defaults. Under Reset To Factory Defaults you have options to Reset settings to Factory Default or Deactivate accounts.
Sep 02, 2012 | Vizio VBR220 Blu-Ray Player
My vizio vbr120 will play dvd but not blu ray
This is a common problem in blu ray discs, the reason why it won't play is because they play at a faster speed and demand a higher precision to produce the high definition signal required to play the program. The only way to fix this is to replace the whole laser pickup assembly which would not be cost effective.
Apr 21, 2012 | Vizio VBR120 Player
Visio LCD LED 3D tv how do you watch tv in 3D?
For the M3D420 Vizio TV, you need a 3D source connected to the TV with an HDMI cable that supports 3D. Some older HDMI cables will not carry all of the data of a 3D source. Turn off the set top box (for example a 3D Blu-ray player). Set your TV to the correct input (press the Input button on your remote). Then turn on the set top box and (for the Blu-ray player) insert your 3D content disc. Start playing the movie. When you see the prompt "3D content detected", highlight Yes to switch to 3D display and press OK to start the 3D playback.
After selecting Yes and pressing OK, then put on your 3D glasses. Make sure that you are sitting with your eyes level with the TV screen eye-line and looking straight at the screen. (If you are off-line, you will not get the 3D experience.)
These directions probably apply to all 3D Vizio TVs. I hope this helps.
Dec 28, 2011 | Televison & Video
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
I cannot switch to 1080p on my Vizio. It is a full HD TV but will not do 1080p and I can't switch resolution off of 480p even with a Blu-Ray.
The resolution is not set at the TV, it is set by the video sources. The TV will detect the resolution and display what it is receiving.
1080P signal = 1080p display.
Does it do that on all sources?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 25, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio VBR220 Blu-Ray Player Logo
20 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
